05-29-2017 10:39 AM - edited 03-05-2019 08:37 AM
I have a Nexus C93108TC-EX switch.
Software
BIOS: version 07.59
NXOS: version 7.0(3)I4(5)
BIOS compile time: 08/26/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.5.bin
NXOS compile time: 12/23/2016 16:00:00 [12/24/2016 01:37:34]
In each QSFP slot, I need a 10Gig connection. QSFP port 49 - 54
So I place in each slot a CVR-QSFP-SFP10G module with in a SFP type SFP-10G-LR.
But I can not make a connection.
When I do a show inventory I see the next.
NAME: Ethernet1/49, DESCR: CISCO-DNI
PID: QSFP-Cazadero , VID: CAZADERO-R , SN: DTY195000W4
NAME: Ethernet1/50, DESCR: CISCO-DNI
PID: QSFP-Cazadero , VID: CAZADERO-R , SN: DTY195000FU
NAME: Ethernet1/51, DESCR: CISCO-DNI
PID: QSFP-Cazadero , VID: CAZADERO-R , SN: DTY195000G7
NAME: Ethernet1/53, DESCR: CISCO-DNI
PID: QSFP-Cazadero , VID: CAZADERO-R , SN: DTY195000G4
NAME: Ethernet1/54, DESCR: CISCO-DNI
PID: QSFP-Cazadero , VID: CAZADERO-R , SN: DTY195000FT
But I do not see any SFP !
XXXXXXXX# sh int e 1/49 transceiver
Ethernet1/49
transceiver is present
type is QSFP-Cazadero
name is CISCO-DNI
part number is CAZADERO-R
revision is 03
serial number is DTY195000W4
nominal bitrate is 10000 MBit/sec per channel
cisco id is 13
cisco extended id number is 155
And when I do a show interface :
Ethernet1/49 is down (Link not connected)
admin state is up, Dedicated Interface
Hardware: 1000/10000/25000/40000/50000/100000 Ethernet, address: 00a3.8e08.7c2
4 (bia 00a3.8e08.7c24)
MTU 1500 bytes, BW 100000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
auto-duplex, auto-speed, media type is 40G
Beacon is turned off
Auto-Negotiation is turned on, FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped never
0 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
I have tried to change the port speed but that is not possible.
Has someone any idea what could be wrong ?
Rene
06-22-2017 03:59 AM
Have You configured the interface et1/49 with the command "speed-group 10000"
This will convert the ports 49-54 into 10G
/Mikael
07-27-2017 11:11 AM
I helped a customer with similar situation. I asked them to upgrade to 703I6.1. They did and was able to hard code the interface speed to 10G (use the interface command "speed-group 10000" to hard code the interface speed to 10G). NXOS-703I5.1 is the min code level to get this configuration to work.
QSA (CVR-QSFP-SFP10G) |
NXOS-703I5.1 |
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/40GE_Tx_Matrix.html#_Toc488672400
