Nexus 9K - Encrypted GRE Tunnels
vxlannnn
Is it possible to encrypt GRE tunnels on the Nexus 9K platform?
I can't seem to find any instructions within the 9K documentation.
I'm looking to create a tunnel between three 9Ks and advertise routes between these labs over that tunnel - however there is a requirement that the tunnels are encrypted. The configuration of the actual tunnels is no issue and works as expected.
Could I achieve something similar using VxLAN if that supports encryption?
6 Replies 6
Where does this list encryption?
GRE Tunnel is just tunnel, Entryption different on top of it. that you need to look the guide and support.
BB
But I cannot find any guide specific to Nexus which is why I posted here.
As i know No you cant.
This is what I feared.
