Nexus 9K iBGP
billy_maclin
I have 2 Nx9Ks each with a VRF to an Internet provider. I want the 2 Nexus VRFs to advertise/reflect the routes they learn from their connected ISP to the other VRF over iBGP. I have followed the NX-OS configuration guide and cannot get this to work.
VRF 1 is AT&T ***************************
interface Ethernet1/47
description << ATT Int LAN >>
vrf member ATT-Internet
ip flow monitor flowmon input
no ip redirects
ip address 209.36.218.97/28
ip address 12.49.166.145/29 secondary
ip address 12.49.166.148/29 secondary
ip address 12.133.188.2/24 secondary
ip address 64.132.122.3/24 secondary
hsrp 0
preempt
priority 250
ip 64.132.122.1
no shutdown
interface Ethernet1/48
description << ATT Int WAN >>
bandwidth 500000
no ip redirects
ip address 32.142.144.46/30
no shutdown
router bgp 32300
address-family ipv4 unicast
vrf ATT-Internet
cluster-id 1000
network 12.49.166.144/29
network 12.133.188.0/24
network 64.132.122.0/24
network 209.36.218.96/28
neighbor 32.142.144.45
remote-as 7018
local-as 32300
neighbor 64.132.122.7
remote-as 32300
log-neighbor-changes
route-reflector-client
next-hop-self
VRF 2 is Lumen - 64.132.122.7
description << Lumen Int LAN >>
vrf member Lumen-Internet
no ip redirects
ip address 64.132.122.7/24
ip address 12.133.188.3/24 secondary
hsrp 0
ip 64.132.122.1
no shutdown
description << Lumen Int WAN >>
speed 1000
duplex full
no negotiate auto
bandwidth 500000
no ip redirects
ip address 66.162.22.26/30
no shutdown
router bgp 32300
vrf Lumen-Internet
cluster-id 1000
neighbor 64.132.122.3
remote-as 32300
next-hop-self
neighbor 66.162.22.25
remote-as 3356
local-as 32300
Hi @billy_maclin ,
Sorry, Harold, but you had a comment yesterday saying "I would also suggest adding a filter to avoid advertising the routes
> received from AT&T to Lumen and vice versa." Maybe I misinterpreted your statement????
This suggestion was about not advertising routes from AT&T to Lumen and vice versa, so that you don't become a transit AS. It was not about blocking routes between your border routers.
> Another commenter suggested there is a
route-map
that will fix the
 next-hop-self
issue in NX-OS and get the iBGP peers to act
> right, so I'm going to try that next. Here's that link: https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/213402-understand-next-hop-set-in-ibgp-advertis.html
This is not required and will work just fine with a simple
next-hop-self
as the routes are received from eBGP and propagated to iBGP.
You need to remove the
 local-as
command from the configuration. It is not required in your scenario and will prevent routes from being propagated between your border routers.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
10 Replies 10
Thanks for your reply. I'll test using the
route-map
as shown in the article next week.
Harold Ritter
Level 12
Level 12
Hi @billy_maclin ,
Try with the following modified configs:
AT&T router:
router bgp 32300
vrf ATT-Internet
remote-as 7018
remote-as 32300
next-hop-self
Lumen Router:
router bgp 32300
vrf Lumen-Internet
remote-as 32300
next-hop-self
remote-as 3356
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi @billy_maclin ,
I would also suggest adding a filter to avoid advertising the routes received from AT&T to Lumen and vice versa.
AT&T router:
ip as-path access-list MyASNONLY seq 10 permit "^$"
router bgp 32300
vrf ATT-Internet
filter-list MyASNONLY out
Lumen router:
router bgp 32300
  vrf Lumen-Internet
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
Thanks for your reply, however, you misunderstand what I'm trying to do. I WANT the 2 routers to advertise their respective received ISP routes to each other. In IOS and IOS-XE, this works without issue by specifying
 next-hop-self
on the iBGP peers. In NX-OS, the 2 routers only advertise the routes in their respective network statements.
In my scenario, the firewall has only a default route, so it forwards traffic to the AT&T router, who then just sends it out to the Internet. Traffic comes back on both carriers as it should because I'm advertising my public subnets to both carriers without any modification. But I want the AT&T router to learn about the Lumen routes, so that if Lumen has a better route to a subnet, the AT&T router will forward the traffic to the Lumen router which will then forward it to the Internet.
So I'm trying to send traffic outbound on whichever carrier is seen as the best route rather than sending everything out via AT&T. And I don't want my firewall to participate in BGP with my Internet routers.
Thanks.
Billy
Hi @billy_maclin ,
 next-hop-self
on the iBGP peers.
I understood exactly what you are trying to achieve.
I tested the configuration I provided and it works as expected. AT&T advertises 192.168.100.1/32 and Lumen advertises 192.168.100.2/32. Here's a snapshot of both border routers:
Border1# sh bgp vrf ATT-Internet all
BGP routing table information for VRF ATT-Internet, address family IPv4 Unicast
BGP table version is 33, Local Router ID is 32.142.144.46
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-injected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - best2
Network Next Hop Metric LocPrf Weight Path
*>l12.49.166.144/29 0.0.0.0 100 32768 i
* i12.133.188.0/24 64.132.122.7 100 0 i
*>l 0.0.0.0 100 32768 i
* i64.132.122.0/24 64.132.122.7 100 0 i
*>e192.168.100.1/32 32.142.144.45 0 0 7018 i
*>i192.168.100.2/32 64.132.122.7 0 100 0 3356 i
*>l209.36.218.96/28 0.0.0.0 100 32768 i
Border1#
Border2# sh bgp vrf Lumen-Internet all
BGP routing table information for VRF Lumen-Internet, address family IPv4 Unicast
BGP table version is 42, Local Router ID is 66.162.22.26
*>i12.49.166.144/29 64.132.122.3 100 0 i
* i12.133.188.0/24 64.132.122.3 100 0 i
* i64.132.122.0/24 64.132.122.3 100 0 i
*>i192.168.100.1/32 64.132.122.3 0 100 0 7018 i
*>e192.168.100.2/32 66.162.22.25 0 0 3356 i
*>i209.36.218.96/28 64.132.122.3 100 0 i
Border2#
As you can see, both routers have the route from the opposite side.
Please let us know what does not work.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Sorry, Harold, but you had a comment yesterday saying "I would also suggest adding a filter to avoid advertising the routes received from AT&T to Lumen and vice versa." Maybe I misinterpreted your statement????
I want them to advertise their ISP learned routes to each other, but they will not.
In any case, I started with my routers configured exactly as your sample config, and they do not advertise any learned routes to each other. They advertise only the routes that are configured with network statements.
Here's my current config and a couple show commands:
AT&T
router bgp 32300
vrf ATT-Internet
remote-as 7018
local-as 32300
remote-as 32300
next-hop-self
RWay-Core-Nx93240-1# sh ip bgp sum vrf ATT-Internet
BGP summary information for VRF ATT-Internet, address family IPv4 Unicast
BGP router identifier 32.142.144.46, local AS number 32300
BGP table version is 778684, IPv4 Unicast config peers 2, capable peers 2
43601 network entries and 43603 paths using 11162120 bytes of memory
BGP attribute entries [5595/1029480], BGP AS path entries [4118/77578]
BGP community entries [0/0], BGP clusterlist entries [0/0]
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
32.142.144.45 4 7018 447857 52110 778684 0 0 5w1d 43597
64.132.122.7 4 32300 1259 1251 778684 0 0 00:06:16 2
RWay-Core-Nx93240-1# sh ip bgp neigh 64.132.122.7 routes vrf ATT-Internet
Peer 64.132.122.7 routes for address family IPv4 Unicast:
BGP table version is 778693, Local Router ID is 32.142.144.46
Lumen
router bgp 32300
vrf Lumen-Internet
remote-as 32300
next-hop-self
remote-as 3356
local-as 32300
RWay-Core-Nx93240-2# sh ip bgp sum vrf Lumen-Internet
BGP summary information for VRF Lumen-Internet, address family IPv4 Unicast
BGP router identifier 64.132.122.7, local AS number 32300
BGP table version is 11421299, IPv4 Unicast config peers 2, capable peers 2
419210 network entries and 419212 paths using 107318024 bytes of memory
BGP attribute entries [85956/15815904], BGP AS path entries [63276/1490046]
BGP community entries [21119/1591276], BGP clusterlist entries [0/0]
64.132.122.3 4 32300 1264 1251 11421299 0 0 00:09:51 4
66.162.22.25 4 3356 3853460 85472 11421299 0 0 21:07:47 419205
RWay-Core-Nx93240-2# sh ip bgp neigh 64.132.122.3 routes vrf Lumen-Internet
Peer 64.132.122.3 routes for address family IPv4 Unicast:
BGP table version is 11421322, Local Router ID is 64.132.122.7
route-map
that will fix the
next-hop-self
issue in NX-OS and get the iBGP peers to act right, so I'm going to try that next. Here's that link: https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/213402-understand-next-hop-set-in-ibgp-advertis.html
Thanks very much for your help.
Hi @billy_maclin ,
route-map
that will fix the
 next-hop-self
next-hop-self
 local-as
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
billy_maclin
Removing the
local-as
command from the eBGP peer fixed it. As soon as I removed it from the Lumen eBGP peer, the Lumen router advertised all of the Lumen learned routes to the AT&T router via iBGP.
Harold, thank you again for your help. I'm learning to hate NX-OS a little less every day.
I am glad I could help @billy_maclin . Do not hesitate to let us know if there is anything else we can help with.
Have a great week end
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
