Nexus OSPF
hs08
I have cisco ISR and Nexus 7707 with ospf enabled. Nexus use 40Gbps for reference bandwidth and ISR use 100Mbps.
From R1 perspective cost to reach 10.103.248.1 is 41, and i have though that 40 is cost from R1 to R2 (40 div 1), and 1 is cost from R2 to the host.
My question is, why the cost is not 80 (R1-R2 is 40 and R2-host=40)? Since from R1 to R2 and R2 to the host same using 40Gbps for the bandwidth reference?
38 Replies 38
here cost to 10.103.245.9
Hello @hs08 ,
this is from the router LSA you have posted
Link connected to: a Stub Network
(Link ID) Network/subnet number: 10.103.248.0        --> This host subnet
(Link Data) Network Mask: 255.255.255.0
Number of MTID metrics: 0
>>>>>>>>>>>>>>>>>>>>>>>>>>>> TOS 0 Metrics: 40 !
as you see the cost is 40 then from R1 point of view is 41 as explained by anyone in this thread
You can see by yourself. There is no need to make a lab for this.
Hope to help
Giuseppe
previous example I show you how we calculate the cost
below is I think explain the issue you face
R1-R2 link,
both R1 and R2 send LSA1 for this link, R1 use it LSA1 not what R2 advertise
so I in lab I change cost in R2 to be 40 for link R1-R2 and R1 config default (which is one)
so R1 use it LSA1 cost which is 1 instead of 40
and hence the total cost is
R1-R2 = 1
R2-SW = 10
total cost 11
NOTE:- cisco not recommend mismatch cost in link, this lead to asymmetric
so return to your network
for 10.103.245.9 there are two LSA1
check LSA1 advertise by R1 not R2
MHM
@hs08 any update for this case ?
Also
Router use cost different than NSK for same link interconnect both
Check if you use refrence bandwidth in NSK this can lead to this issue.
MHM
Hi @MHM Cisco World
Still trying to understand, will update soon.
What is not clear to you?
You have issue that why you see different cost in lsa1 for same prefix
Mostly router abd NSK use different refrence bandwidth that make NSK use 40 and router use 1 cost for same link.
It common issue.
MHM
Hi @MHM Cisco World
Currently my nexus is replaced to catalyst 9500 and this make me can't investigate further.
Even if you change platform' if you use wrong refrence BW then issue will appear again
I will try share more detail later today
MHM
Yes, so in my current topology now all link have same reference BW. Thanks
