NHRP Not enabled after interface flap
Liam Devine
Hi All,
I'm configuring a network to run with a dual hub dual cloud DMVPN solution. I am running OSPF over the two clouds.
While doing some resiliency testing I noticed that if the physical interface of one of the hubs connecting it to the WAN is shutdown or unplugged, the tunnels do not come back up when the interface does.
I have tried debugging NHRP and received the message:
NHRP not enabled - ignoring swif coming up event
I haven't been able to find any references to that particular debug message in my searches. Do any of you have any experience of this? Would be much obliged for your input, I'm pulling out what little hair I have left over something that should be relatively simple!
0 Replies 0
