09-22-2006 05:34 AM - edited 03-03-2019 02:05 PM
Router1:
interface Tunnel1
description MULTI-POINT GRE TUNNEL for BRANCHES
bandwidth 1000
ip address 172.16.0.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication dmvpn
ip nhrp map multicast dynamic
ip nhrp holdtime 300
tunnel source FastEthernet0/1
tunnel mode gre multipoint
Router 2:
address tnip1 172.16.0.2 255.255.255.0
network tnip1
; -- IP Tunnel Net Configuration --
mode gre multipoint
source ppp1
nhrp holdtime 300
nhrp map multicast x.x.x.x
nhrp map 172.16.0.1 x.238.66.2 x.x.x.x
nhrp nhs 172.16.0.1
exit
Have tried debug but no packets.
Multicast issue ?
Regards Bjornarsb
09-28-2006 07:37 AM
Did you try publishing the tunnel interfacce in routing protocol ?
11-05-2006 02:52 AM
you have to start ospf as router process with network type broadcast.
regards,
Herbert
