NM-1CE1U card support 2811 router ????
iqbalkhan
I need urgent quary.
I know NM-1CE1U card end of product in cisco.
But can i use this card in 2811 router ?, becuse i have no NM-1CE1T1-PRI card.
and can i surf my work by NM-1CE1U this card.
thanks
Biplob
smothuku
Level 7
Level 7
Hi ,
1-port channelized E1/ISDN-PRI network module, unbalanced i.e NM-1CE1U is not supported on 2811 router.
Below link has info about the cards supporting routers.
http://www.cisco.com/en/US/partner/products/hw/modules/ps2797/products_module_installation_guide_chapter09186a008007c8c4.html
Hope it helps you.
satish
It supports 2600 series router ??
Hi ,
The following routers supports the card .
Cisco 2600 series
Cisco 3600 series
Cisco 3700 series
Hope it helps you.
satish
