NIM-2MFT-T1/E1 not showing up as serial interfaces for MPLS
Travis-Fleming
Hello. We have an ISR 4331/K9 with voice and security license on them.
A show inventory shows our NIM card installed:
"NAME: "NIM subslot 0/2", DESCR: "NIM-2MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-2MFT-T1/E1 , VID: V05 , SN: FOC23354FUE"
I've configured the controllers as T1 as below from show controllers t1 command. However when I do a show ip int brief, I"m not seeing the serial interfaces as I would expect to configure the MPLS T1's? We will have 2 1.5 T1's setup in a multilink fashion.
What am I missing here? They don't have cables plugged in as I'm staging them at our HQ then shipping onsite to another state.
Router(config)#do sh controllers t1
T1 0/2/0 is down
Applique type is Channelized T1
Cablelength is long gain36 0db
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Failure LOF State:Clear
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
BER thresholds: SF = 10e-3 SD = 10e-6
Data in current interval (3 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 3 Unavail Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
T1 0/2/1 is down
Data in current interval (2 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2 Unavail Secs
26 Replies 26
Travis-Fleming
I was able to get them to show up, but they look different then I've seen before. I configured a multilink, then joined each controller to the channel-group as follows. I do see serial interface now, but they are labeled ending with a :1, guessing for the timeslot. Is the timeslot needed? I haven't seen this with our 2911's before. Also when I configure a laptop with the next hop IP of the MPLS connection and plug it in, nothing happens. And the right amber light stays solid on both interfaces.
serial0/2/0:1
serial0/2/1:1
Router(config)#int multilink 1
Router(config-if)#ip address X.X.X.X 255.255.255.252
Router(config-if)#encapsulation ppp
Router(config-if)#ppp multilink
Router(config)#controller t1 0/2/0
Router(config-controller)#channel-group 1 timeslots 1
Router(config)#controller t1 0/2/1
check if you have configured 'network-clock synchronization automatic' configured globally. The clocking on the E1/T1 modules is different on the ISR 4K routers...
Check the link below for reference:
Configuring the Cisco Fourth-Generation T1/E1 Voice and WAN Network Interface Module
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4gen-t1-e1-nim-guide.html
Thanks George. I tried that and still shows error on the card, and no up status. Below is what I have in running config now.
EDIT: Both the yellow and green lights on the NIM are solid now as apposed to just solid yellow before
controller T1 0/2/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
clock source network
linecode b8zs
cablelength long 0db
controller T1 0/2/1
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
interface Multilink1
ppp multilink
ppp multilink group 1
your T1 receivers have a loss of signal, this usually indcates some sort of cabling problem...
Try and disable backplane clock participation with the command:
--> no network-clock synchronization participate [slot | subslot]
Also, remove the 'clock source' from the controllers...
controller T1 0/2/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
--> no clock source network
linecode b8zs
controller T1 0/2/1
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
Thank you for the reply. Now however I just have solid yellow lights on the interface. Below is current running config as it relates to the card.
controller T1 0/2/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
controller T1 0/2/1
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
no network-clock synchronization participate 0/2
what if you use 'clock source line' ?
Same result. Must be the default because when I put that on the controller it doesn't show in a running config, even after a restart.
Seems like this should be simpler? New 4331 router, new NIM card, need to setup a bonded T1 multilink for MPLS connection. Attached is my running config now including a show inventory and ip int brief.
the values to be used usually are provided by your ISP, so it becomes a bit of guesswork what you need.
On the controllers, try 'clock source internal' which I think goes with the channel-group:
controller T1 0/2/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
--> clock source internal
controller T1 0/2/1
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
If that doesn't make any difference, also try 'fdl both' on the controllers...
Would it help to have the config from the current 2911 device with 2 WIC T1 cards currently running? They don't have 2 T1's yet, we have that on order, we only have a single 1.5 MBps T1 today. Below is the serial interface config of the current 2911 router we're replacing with this 4331. I will try your settings as well. I'll note again, the new router is sitting in my datacenter, and it's replacing a router across the country. I only have a laptop I can hook up to the T1 interfaces. I also put in a ticket with CenturyLInk to see if they can provide me with any sort of direction.
interface Serial0/0/0
description CID-Centurylink DS1IT-XXXX
ip flow ingress
ip flow egress
no service-module t1 remote-loopback full
service-module t1 timeslots 1-24
service-policy output wanedge
the config is different on the ISR. I am pretty sure there is something missing with regard to the clocking. Try and globally configure:
clock source line primary
network-clock input-source 1 controller t1 0/2/0
This is what I was able to configure. Let me know. Still not able to get a link light on my laptop directly connected, and the multilink and serial interfaces say down.
network-clock input-source 1 controller T1 0/2/0
controller T1 0/2/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
controller T1 0/2/1
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
I found a bug related to the lines:
threshold sd-ber 6
threshold sf-ber 3
These are not supposed to be in the configuration of the 4331, can you try and remove them ?
I cannot remove them...
wt-latx-mpls-rt01(config)#controller t1 0/2/0
wt-latx-mpls-rt01(config-controller)#no threshold sd-ber 6
wt-latx-mpls-rt01(config-controller)#no threshold sf-ber 3
wt-latx-mpls-rt01(config-controller)#exit
wt-latx-mpls-rt01(config)#exit
wt-latx-mpls-rt01#sh run | sect controller
controller T1 0/2/0
threshold sd-ber 6
threshold sf-ber 3
framing esf
linecode b8zs
The ISP did also get back to me on clock settings, and they said the below. I've set those settings as well, still no joy.
From the ISP:
"Hello customer this circuit is set as B8zs frame esf and you should go with  the defaults and set the clock source to line."
try 'cablelength short'. I am pretty sure the problem is at layer 1...
Also, try to change the encapsulation on the multilink interface to HDLC and back to PPP:
Router(config-if)#encapsulation hdlc
Router(config-if)#shut
Router(config-if)#no shut
