NIM card in booting state
Yasir@1995
Hi all,
I am stuck in a problem.
In ISDN layer in DEACTIVATED state. when I checked the NIM card status I can see that it stuck in booting state.
The router was running with the following version:
IOS: 15.5
ROMMON:16.7
Now we have upgraded the router version to the latest version.
But still the NIM card in booting state.
Can anybody suggest anything to resolve the issue.
I guess after the upgrade you have tried to reseat the card (remove it and put it back in) ?
What device is this on (e.g. ISR4K) ? IOS 15.5 sounds rather old...
6 Replies 6
Yasir@1995
We already reseated the module.
Device: ISR4321
IOS : 17.3.4a
not good. I see there is another NIM that is 'booting' as well. Can you try and swap the slots (that is, install the NIM in the other slot) ?
During the primary troubleshooting , performed the swapping.
Also tried to force restart of this slot.
Is there any chance if I replace the NIM card with new one.
replacing the card is of course an option, if you can easily do that. Not sure if this is a production unit, but you could try and downgrade the IOS to let's say a late 16.x or earlier 17.x version.
Yasir@1995
Also on the router throwing the traceback error
