NM-HDV2-1T1/E1 VS NM-HDV-1E1-30
leechehcheng
What is the different between these two? In term of pricing, a lot of different. Our purpose is to segmentize the FULL E1(2M) lease line into different rate. Can we use NM-HDV2-1T1 instead of NM-HDV-1E1-30? Please advise
b.hsu
Level 5
Level 5
NM-HDV2-1T1/E1 is 1-port T1/E1 IP communications high-density digital voice/fax network module
NM-HDV-1E1-30 is 1-port 30-channel E1 voice/fax network module Bundle: NM-HDV with one (1) VWIC-1MFT-E1 and three (3) PVDM-12s
thisisshanky
Level 11
Level 11
These modules are designed primarly for voice circuits, though they do have the capability to run data circuits. The NM-HDV2s are the second generation high density voice modules and they succeed the NM-HDV's which are the first gens. NM-HDV2s are supported only in 2600XMs, the new ISRs etc. ( I dont think, the 3600s support that, though 3700s do).
The NM-HDV2 comes in three flavours.
a.NM-HDV2 - no onboard ports, one vwic slot
b.NM-HDV2-1T1/E1 - 1 T1/E1 onboard port, one wic slot
c.NM-HDV2-2T1/E1 - 2 T1/E1 onboard ports, one wic slot
b. and c. have onboard ports which can be configured as a T1 or E1 port using the command
"card type t1|e1 " from global config mode.
All three modules have an optional vwic slot which can home a voice vic such as vwic's or vic's
The NM-HDV2 also has four onboard PVDM slots and they use a higher density DSP chip called the PVDM2's. THe PVDM2 is available in various flavours,
a. PVDM2-8
b. PVDM2-16
c. PVDM2-24
d. PVDM2-32
e. PVDM2-48
f. PVDM2-64
These PVDM2s cannot be used in NM-HDV's. They can only be used in NM-HDV2s or the onboard DSP slots of a 2800 or 3800 router.
NM-HDV has no onboard ports for T1/E1. It only has one vwic slot which can take a vwic or vic. You have to get a vwic that is either a t1 or e1. These modules use a lower density DSP chip called PVDM-12. You have 5 slots in this module and can home 5 PVDM-12's giving 60 channel density per module.
The price difference between the two modules are almost the same (NM-HDV and NM-HDV2), so I would suggest you to go for NM-HDV2.
Again to conclude, these modules are primarily designed for voice though they have capability to run data circuits. There are other NMs available for running strictly data.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
