QOS GTS shaping without effect on cisco ISR G2 2900
jmolines42
I try to setup a basic GTS shaping on a cisco ISR G2 2900
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Cisco CISCO2901/K9 (revision 1.0) with 1957856K/40960K bytes of memory.
ipbase        ipbasek9      Permanent      ipbasek9
the policy-map was applied to a svi interface (vlan interface)
And my problem is the shape isn't effective, in my attempt the max bw is 20Mb and I have gigabit interface
I know this kind of setup is classic and I see it working on older ios version 12.x
config:
interface VlanX
ip address X X
no ip redirects
no ip proxy-arp
ip ospf dead-interval 2
ip ospf hello-interval 1
ip ospf priority 200
ip ospf retransmit-interval 1
service-policy output shape_qos
end
policy-map shape_qos
class class-default
  shape average 20000000
router#sh policy-map  interface vlanX
VlanX
  Service-policy output: shape_qos
    Class-map: class-default (match-any)
      3119629 packets, 4367428400 bytes
      5 minute offered rate 67417000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 1612/231119
      shape (average) cir 20000000, bc 80000, be 80000
      target shape rate 20000000
Thanks for any ideas
ravikantt
  Hi Jacques,
I think GTS is not sported on SVI on ISRs as per below cisco link.
Class-Based Traffic Shaping
Provides Generic Traffic Shaping based on user defined traffic class
No
Generic-Traffic Shaping
Limits the transmission rate of data to match the speed of the remote, target interface and helps ensure that the traffic conforms to policies contracted for it
No
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_white_paper0900aecd8064c9f4.html
and you'll see there policing is supported which was also happening in your case.
Policing
Limits the input or output transmission rate on SVI and specifies traffic handling policies when the traffic either conforms to or exceeds the specified rate limits
Yes (15.1(1)T or later)
6 Replies 6
Hello
I see you are applying this to the svi?
Is this for rate limting your vlan?
You may need to apply
Mls qos vlan-based on the trunks
Res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
it's a SVI L3 interface on a router, mls setup is for switch only ?
Abdessamad
jmolines42
after made a poc, I found this:
  • If I use a integrated interface, policy and shaping works
  • If I use a port on the etherswitch module, policy works and shaping don't work
I tried to upgrade to 15.3(2)T, without effect.
any ideas ?
Abdessamad
That is normal, certain QoS commands are not supported at level of individual switched ports, because the are not layer 3 ports.
Apply them on the VLAN interface instead.
ravikantt
  Hi Jacques,
No
No
Policing
thanks ashok
Abdessamad
