No DSCP packets matched at one end - QoS on Multilink PPP (Bonded T1)
v4meet999
The issue is DSCP is preserved from SiteA to SiteB whereas DSCP marking is not preseved from SiteB to SiteA.
  (Site A) Phone----Cisco 3560 SW----Cisco 1921 Router========(Bonded T1)=========Cisco 1921 Router-----Cisco 2960 SQ---Phone (Site B)
Site A Config (on 1921 Router):==========
controller T1 0/0/0
 cablelength short 110
 channel-group 0 timeslots 1-24
controller T1 0/0/1
class-map match-all SiteA-CLASS-VOICE
 match ip dscp ef
policy-map SiteA-POLICY-VOICE
 class SiteA-CLASS-VOICE
    priority percent 35
interface Multilink1
 ip address 10.10.10.2 255.255.255.252
 no ip redirects
 no ip unreachables
 ppp multilink
 ppp multilink group 1
 ppp multilink fragment disable
 no cdp enable
 service-policy output SiteA-POLICY-VOICE
interface GigabitEthernet0/0
 ip address 192.168.1.49 255.255.255.0
 no ip redirects
 no ip unreachables
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:0
 no ip address
 encapsulation ppp
 ppp multilink
interface Serial0/0/1:0
 no ip address
 encapsulation ppp
 ppp multilink
Site B Config (on 1921 Router):=======
controller T1 0/0/0
 clock source internal
controller T1 0/0/1
class-map match-all SiteB-CLASS-VOICE
 match ip dscp ef
policy-map SiteB-POLICY-VOICE
 class SiteB-CLASS-VOICE
    priority percent 35
 class class-default
    fair-queue
interface Tunnel1
 no ip address
 ip address  10.10.10.1 255.255.255.252
 no ip redirects
 no ip unreachables
 ppp multilink
 no cdp enable
 service-policy output SiteB-POLICY-VOICE
 ip address  10.20.30.1 255.255.255.0
 no ip redirects
 no ip unreachables
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 encapsulation ppp
 ppp multilink
 no ip address
 encapsulation ppp
 ppp multilink
Output of "show policy-map interface Multilink1" on Cisco 1921 Router at SiteB:
 Multilink1
  Service-policy output: SiteA-POLICY-VOICE
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 462007/93479526
    Class-map: SiteA-CLASS-VOICE (match-all)
      462007 packets, 93479526 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
      Priority: 35% (1075 kbps), burst bytes 26850, b/w exceed drops: 0
    Class-map: class-default (match-any)
      31243043 packets, 4643228349 bytes
      5 minute offered rate 6000 bps, drop rate 0 bps
      Match: any
      (queue depth/total drops/no-buffer drops) 0/7/0
      (pkts output/bytes output) 31243036/4431006764
 Multilink1
  Service-policy output: SiteB-POLICY-VOICE
      (pkts output/bytes output) 0/0
    Class-map: SiteB-CLASS-VOICE (match-all)
      0 packets, 0 bytes
      36561971 packets, 31606577408 bytes
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/70746/0/70720
      (pkts output/bytes output) 36491225/31471175701
      Fair-queue: per-flow queue limit 16
Can anyone figure out what is wrong with this config ?
Hitesh Vinzoda
Level 4
Level 4
You should look at the phone and Switch @ Site B to check if the phone is setting the correct DSCP to EF and whether switch is honoring the dscp values marked by the phone.
By default Cisco switch has got QOS disabled. you should enable it and using below commands
<config>mls qos
on the port connected to phone
<config>mls qos trust dscp
Hitesh
Hitesh Vinzoda
Level 4
Level 4
<config>mls qos
Hitesh
I had to enter QoS command on trunk port on 2960 Switch at Site B and that solved the problem. Thank you.
