no EIGRP neighship is being formed.
prabinchand
Hello EXPERTS,
I have configured EIGRP 100 on HEAD-OFFICE and BRANCH-1 but no neighborship is formed. OR i haven't understood the routing properly, if so, please make me clear. I will be very thankful to you guys!!.
Topology is attached below.
no any config shoud be applied on ISP side.
CONFIGURATION
ISP-INTERNET:
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15245A44-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
ip address 1.1.1.2 255.255.255.252
clock rate 2000000
interface Serial0/3/1
ip address 2.2.2.2 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 2.2.2.1
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
HEAD-OFFICE:
version 15.1
hostname HEAD-OFFICE
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524JH3H-
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.50.1 255.255.255.0
duplex auto
speed auto
ip address 1.1.1.1 255.255.255.252
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 100
network 192.168.10.0
network 192.168.20.0
network 1.1.1.0 0.0.0.3
network 192.168.50.0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
BRANCH-1:
Current configuration : 1226 bytes
version 15.1
hostname BRANCH-1
enable secret 5 $1$mERr$aI/DxI917YEQARn3zkBDJ0
aaa new-model
aaa authentication login default group radius local
aaa accounting exec default start-stop group radius
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524NG67-
ip ssh version 2
ip domain-name cisco.com
ip address 192.168.30.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
ip address 2.2.2.1 255.255.255.252
interface Vlan1
no ip address
shutdown
router eigrp 100
network 192.168.30.0
network 2.2.2.0 0.0.0.3
ip classless
radius-server host 192.168.20.2 auth-port 1645 key i@mradius
line con 0
line aux 0
line vty 0 4
line vty 5 10
login authentication default
end
24 Replies 24
The original post asks " OR i haven't understood the routing properly," Pretty clearly the understanding of routing is not correct. A fundamental aspect of running EIGRP is that a neighbor relationship is formed only when the routers involved are connected on a common subnet. Head-Office is running "EIGRP on Serial0/3/0" and Branch-1 is running "EIGRP on Serial0/3/1". But these interfaces are not on a common subnet and so no neighbor relationship is formed.
There are several ways that the original poster can get this to work.
1) run EIGRP on both serial interfaces of ISP router. But a requirement in the original post is that no changes are to be made on ISP router. So this would not work.
2) configure a simple GRE tunnel between Head-Office and Branch-1 and run EIGRP on the tunnel interface (removing the network statements for the serial interfaces). This would be the most simple solution.
3)  configure an encrypted tunnel between Head-Office and Branch-1 and run EIGRP over the encrypted tunnel. This might be DMVPN, or VTI, or ipsec over GRE.
Rick
i tired your suggestion number.2 but it didn't worked.
My quesiton is, how can branch communicate with Head office when it dont know the route for head office.
Using 2nd suggestion i did the same as u said but yet no neighborship is formed and condition is i cannot use any static route on HEADOFFICE AND BRANCH.
now what will be the way?
Hello
.Well it wont be able to connect - you need some sort of transit path between the head/branch offices, be it via the internet or direct connection, at least some sort of connectivity.
example
If the head off and branch offices are internet facing then the internet is the transit path as such you would then secure that connection with say an "ipsec/gre" tunnel and run eigrp over that tunnel.
Kind Regards
Paul
ISP has provided different network for HEAD-OFFICE and BRANCH so how can i do communicate those between without using statice route.  Default route can only be applied on ISP router & HEAD-OFFICE and BRANCH should use EIGRP.
What can be the solution for this ?
Hello
I assume your branch office has a isp circuit?  (internet/mpls etc..) And your head off has a internet facing presence?
Can you confirm the transit connectivity?
Kind Regards
Paul
i dont know about those transit sir, I am doing this lab on my own. I got curious, how can branch and head office can commmunicate without using any static ip.
--> I am doing this lab on my own
Are you following any instructions at all, or did you come up with the topology (and subsequent question) by yourself ? We are under the assumption that you are following a scripted lab. If that is not the case, the answer is simply: no, it won't work. As @paul driver mentioned, you need a common subnet between EIGRP neighbors.
Hello
okay pick an ip range  that the Hq /branch rtts can communicate on.
The below example should provide eigrp adjacency between HQ and Branch office.
HQ
int x/x
description link to branch
ip address 10.1.12.1 255.255.255.252
router eigrp 1
no auto
network 10.1.12.1 0.0.0.0
Branch
int x/x
description link to HO
ip address 10.1.12.2 255.255.255.252
router eigrp 1
no auto
network 10.1.12.2 0.0.0.0
Kind Regards
Paul
The original poster has created a set of mutually contradictory requirements. The Head Office knows 3 connected LAN subnets and a potential transit network over the serial interface. But it has no other routing knowledge. The Branch knows 1 connected LAN subnet and a potential transit network over the serial interface. So both the Head Office and the Branch know locally connected subnets but have no routing logic for anything remote. And the other condition is:
Condition is no any static route shoud be used on BRANCH and HEAD-OFFICE.
Given this requirement there is no way for this project to work.
For this project to work either the ISP router needs additional routing information, in particular if the ISP router would run EIGRP with the other 2 routers it would be successful. Or if the Head Office and Branch had some default route it would be successful. Or if the Head Office and the Branch had a route for the transit network of the other side it would work. But with the current restrictions I do not see any way that it could work.
Rick
