No internet access other than default vlan.
suriya7
Hi Team,
Need your help on this.
I have configured Router 2951 with sub-ip on GigabitEthernet0/1 for multiple vlans and switch WS-C3750X-48P-L with trunk port and multiple vlans. I can able to access the internet on the default vlan 1(192.168.2.0), but no internet access in other vlans.
Also I couldn't ping the ip assigned to desktop from switch or router from same subnet.
Example - ping 192.168.5.6 source 192.168.5.1 - from router is not pingable.
Switch - config
Current configuration : 6808 bytes
! Last configuration change at 17:03:33 UTC Mon Jan 2 2006
version 15.0
no service pad
hostname
boot-start-marker
boot-end-marker
enable secret 5
enable password
username
no aaa new-model
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip domain-name
cts server deadtime 0
no cts server test all enable
cts server test all idle-time 0
cts server test all deadtime 0
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 no ip route-cache
 shutdown
interface GigabitEthernet1/0/1
 switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
 switchport access vlan 10
 switchport mode access
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
 switchport access vlan 20
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
 switchport access vlan 30
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
 switchport access vlan 40
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
 ip address 192.168.2.2 255.255.255.0
 no ip route-cache
interface Vlan10
 no ip address
 no ip route-cache
interface Vlan20
 no ip address
 no ip route-cache
interface Vlan30
 ip address dhcp
 no ip route-cache
interface Vlan40
 ip address dhcp
 no ip route-cache
ip http server
ip http secure-server
line con 0
 logging synchronous
 login local
line vty 0 4
 password
 login local
 transport input ssh
line vty 5 15
 password
 login
end
Router Config :
Current configuration : 3618 bytes
! Last configuration change at 12:42:04 UTC Mon Jan 11 2021 by admin
version 15.1
service password-encryption
hostname
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.5
ip dhcp excluded-address 192.168.3.255
ip dhcp excluded-address 192.168.4.1 192.168.4.5
ip dhcp excluded-address 192.168.4.255
ip dhcp excluded-address 192.168.5.1 192.168.5.5
ip dhcp excluded-address 192.168.5.255
ip dhcp excluded-address 192.168.6.1 192.168.6.5
ip dhcp excluded-address 192.168.6.255
ip dhcp pool mainuser
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 8.8.8.8
ip dhcp pool vlan10
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   dns-server 8.8.8.8
ip dhcp pool vlan20
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
   dns-server 8.8.8.8
ip dhcp pool vlan30
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   dns-server 8.8.8.8
ip dhcp pool vlan40
   network 192.168.6.0 255.255.255.0
   default-router 192.168.6.1
   dns-server 8.8.8.8
ip domain name
license udi pid CISCO2951/K9 sn
username
username
redundancy
interface GigabitEthernet0/0
 ip address 192.168.1.2 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 description vlan10_subinterface
 encapsulation dot1Q 10
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.20
 description vlan20_subinterface
 encapsulation dot1Q 20
 ip address 192.168.4.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.30
 description vlan30_subinterface
 encapsulation dot1Q 30
 ip address 192.168.5.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 192.168.6.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
router eigrp 10
 network 192.168.2.0
 network 192.168.3.0
 network 192.168.4.0
 network 192.168.5.0
 network 192.168.6.0
ip default-gateway 192.168.1.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 192.168.3.0 255.255.255.0 192.168.2.2
ip route 192.168.4.0 255.255.255.0 192.168.2.2
ip route 192.168.5.0 255.255.255.0 192.168.1.254
ip route 192.168.5.0 255.255.255.0 192.168.2.2
ip route 192.168.6.0 255.255.255.0 192.168.2.2
access-list 1 permit any
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.6.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
 password
 login local
 transport input ssh
scheduler allocate 20000 1000
end
10 Replies 10
balaji.bandi
Router make sure parent interface dont have any config, if you looking dot1q to work
here is example :
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
BB
make the changes marked in bold:
Switch
version 15.0
no service pad
hostname
boot-start-marker
boot-end-marker
enable secret 5
enable password
username
no aaa new-model
ip domain-name
no ip address
no ip route-cache
shutdown
interface Vlan1
no ip route-cache
--> ip default-gateway 192.168.2.1
--> no interface Vlan10
no ip address
no ip route-cache
--> no interface Vlan20
no ip address
no ip route-cache
-> no interface Vlan30
ip address dhcp
no ip route-cache
--> no interface Vlan40
ip address dhcp
no ip route-cache
ip http server
line con 0
logging synchronous
login local
line vty 0 4
password
login local
transport input ssh
line vty 5 15
password
login
end
Router
version 15.1
hostname
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
dns-server 8.8.8.8
ip dhcp pool vlan10
dns-server 8.8.8.8
ip dhcp pool vlan20
dns-server 8.8.8.8
ip dhcp pool vlan30
dns-server 8.8.8.8
ip dhcp pool vlan40
dns-server 8.8.8.8
ip domain name
username
username
redundancy
ip nat outside
duplex auto
speed auto
no mop enabled
ip nat inside
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat inside
no ip address
shutdown
duplex auto
speed auto
router eigrp 10
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
--> no ip default-gateway 192.168.1.254
no ip http server
--> no ip route 192.168.3.0 255.255.255.0 192.168.2.2
--> no ip route 192.168.4.0 255.255.255.0 192.168.2.2
--> no ip route 192.168.5.0 255.255.255.0 192.168.1.254
--> no ip route 192.168.5.0 255.255.255.0 192.168.2.2
--> no ip route 192.168.6.0 255.255.255.0 192.168.2.2
--> no access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
password
login local
transport input ssh
end
I agree with the changes that @Georg Pauwen suggests. Be careful about this one
It is likely that the result of this command is that all of the access list will be removed and not just the single line. You man need to manually add the other lines back into the config.
It might be helpful in understanding the issue if you would post the output of these commands on the switch
show interface trunk
show interface status
and of these commands on the router
show ip interface brief
show arp
Rick
Hello
Can you try the following and test again:
switch
no ip routng
interface Vlan1
ip route-cache
no interface Vlan10
no interface Vlan20
no interface Vlan30
no interface Vlan40
vlan 10,20,30,40
exit
Rtr1
no ip source-route
no router eigrp 10
no ip route 0.0.0.0 0.0.0.0 192.168.1.254
access-list 1 permit 192.168.2.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.1.254
Kind Regards
Paul
ip address 192.168.2.1 255.255.255.0<- this IP assign to main interface, please add sub interface and assign this ip to it instead assign ip to main interface.
Just a remark: untagged traffic for Vlan 1 typically actually DOES go on the physical interface.
In this case, this is also the only traffic that DOES work, so it is definitely no misconfiguration.
You are right @Georg Pauwen It works fine. Sorry for the confusion.
as I can see there is two L3 connect to each other,
SW have SVI for native VLAN only and it connect to L3 route-port and hence the connection is OK
SW have not SVI for other VLAN and hence the connection to internet is failed ?
only
NO ip routing in SW solve this,
and also make sub-interface for active to check.
Where do you see IP routing enabled on the switch ? Interface GigabitEthernet1/0/1 is trunked to the router for a router-on-a-stick setup. The switch does not do any routing.
suriya7
Thanks Everyone for your reply and time   Sorry the above config works perfectly, It was not tested properly, because this setup I did in remote on the other end the person who done testing had some issues with his laptop used to test with other vlans
I will do the best practices said above. Once again thanks everyone for your valuable time
Suriya
