No Internet connection via PPPoE (FTTH)
krevero
Hey,
I have troubles to connect the internet from the router and the clients behind. The pppoe connection seems to be established, I got an ip address but no internet connection.  Need help!
My configuration (ISR1100-6G):
version 17.9
service password-encryption
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname xxxxx
boot-start-marker
boot system bootflash:packages.conf
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone CET 1 0
ip name-server 8.8.8.8 8.8.4.4
no ip domain lookup
ip dhcp pool xxx
network 172.20.100.0 255.255.255.0
default-router 172.20.100.1
dns-server 8.8.8.8
ip dhcp pool xxxx
network 172.20.110.0 255.255.255.0
default-router 172.20.110.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool xxx
network 172.20.120.0 255.255.255.0
default-router 172.20.120.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool xxx
network 172.20.130.0 255.255.255.0
default-router 172.20.130.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool xxx
network 172.20.140.0 255.255.255.0
default-router 172.20.140.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool xxx
network 172.20.150.0 255.255.255.0
default-router 172.20.150.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool xxx
network 172.20.160.0 255.255.255.0
default-router 172.20.160.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool xxx
network 172.20.170.0 255.255.255.0
default-router 172.20.170.1
dns-server 8.8.8.8
lease 0 12
ip dhcp pool Tesaro
network 172.20.180.0 255.255.255.0
default-router 172.20.180.1
dns-server 8.8.8.8
lease 0 12
login on-success log
subscriber templating
vtp version 1
vpdn enable
vpdn-group 1
crypto pki trustpoint SLA-TrustPoint
crypto pki trustpoint TP-self-signed-996081189
crypto pki certificate chain SLA-TrustPoint
quit
license ###
license ###
memory free low-watermark processor 62972
diagnostic bootup level minimal
enable password 7 ####
username admin privilege 15 password 7 ###
redundancy
mode none
track 1 ip sla 1 reachability
interface GigabitEthernet0/0/0
description ISP
no ip address
negotiation auto
interface GigabitEthernet0/0/0.7
encapsulation dot1Q 7
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
ip nat inside
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3.100
encapsulation dot1Q 100
interface GigabitEthernet0/0/4
description Switch Uplink
ip address 172.20.100.1 255.255.255.0
ip nat inside
negotiation auto
spanning-tree portfast trunk
interface GigabitEthernet0/0/4.110
encapsulation dot1Q 110
ip address 172.20.110.1 255.255.255.0
interface GigabitEthernet0/0/4.120
encapsulation dot1Q 120
ip address 172.20.120.1 255.255.255.0
interface GigabitEthernet0/0/4.130
encapsulation dot1Q 130
ip address 172.20.130.1 255.255.255.0
interface GigabitEthernet0/0/4.140
encapsulation dot1Q 140
ip address 172.20.140.1 255.255.255.0
interface GigabitEthernet0/0/4.150
encapsulation dot1Q 150
ip address 172.20.150.1 255.255.255.0
interface GigabitEthernet0/0/4.160
encapsulation dot1Q 160
ip address 172.20.160.1 255.255.255.0
interface GigabitEthernet0/0/4.170
encapsulation dot1Q 170
ip address 172.20.170.1 255.255.255.0
interface GigabitEthernet0/0/4.180
encapsulation dot1Q 180
ip address 172.20.180.1 255.255.255.0
interface GigabitEthernet0/0/5
no ip address
shutdown
negotiation auto
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1442
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp mtu adaptive
ppp authentication chap callin
ppp chap hostname xxx@xxx
ppp chap password 7 xxx
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
interface Dialer2
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip nat inside source list 197 interface Dialer1 overload
ip nat inside source route-map track-primary-if interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip ssh version 2
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer2
ip sla schedule 1 life forever start-time now
ip access-list extended 197
10 permit ip any any
20 permit icmp any any
30 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map track-primary-if permit 1
match ip address 197
match interface Dialer1
route-map track-secondary-if permit 1
control-plane
line con 0
stopbits 1
line aux 0
line vty 0 4
length 0
transport input ssh
line vty 5 14
transport input ssh
ntp server ip ptbtime1.ptb.de
ntp server ip 0.de.pool.ntp.org prefer
end
sh ip int brief  (Dialer 1 is binded to Virtual-Access2)
GigabitEthernet0/0/0 unassigned YES NVRAM up up
GigabitEthernet0/0/0.7 unassigned YES manual up up
GigabitEthernet0/0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/2 192.168.1.1 YES NVRAM up up
GigabitEthernet0/0/3 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/4 172.20.100.1 YES NVRAM down down
Gi0/0/4.110 172.20.110.1 YES NVRAM down down
Gi0/0/4.120 172.20.120.1 YES NVRAM down down
Gi0/0/4.130 172.20.130.1 YES NVRAM down down
Gi0/0/4.140 172.20.140.1 YES NVRAM down down
Gi0/0/4.150 172.20.150.1 YES NVRAM down down
Gi0/0/4.160 172.20.160.1 YES NVRAM down down
Gi0/0/4.170 172.20.170.1 YES NVRAM down down
Gi0/0/4.180 172.20.180.1 YES NVRAM down down
GigabitEthernet0/0/5 unassigned YES NVRAM down down
Dialer1 87.148.xx.xxx YES IPCP up up
Dialer2 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES NVRAM up up
debug pppoe events
debug pppoe negotiation
clear interface dialer 1
*Jan 30 14:32:43.578: PPPoE : Shutting down client session
*Jan 30 14:32:43.579: PPPoE VLAN CoS (pppoe_send_padt)=>GigabitEthernet0/0/0.7 :: cos=0x0
*Jan 30 14:32:43.579: [0]PPPoE 11: O PADT R:ec13.db13.1cac L:c828.e555.4c21 Gi0/0/0.7
*Jan 30 14:32:43.581: PPPoE: Failed to add PPPoE switching subblock
*Jan 30 14:32:43.582: Vi2 PPP DISC: Authentication configuration changed
*Jan 30 14:32:43.582: Vi2 PPP: Sending Acct Event[Down] id[18]
*Jan 30 14:32:43.582: PPP: NET STOP send to AAA.
*Jan 30 14:32:43.582: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Jan 30 14:32:43.584: Vi2 PPP: Block vaccess from being freed [0x10]
*Jan 30 14:32:43.593: Di1 Deleted neighbor route from AVL tree: topoid 796304859762330381, address 62.155.xxx.xxx
*Jan 30 14:32:43.593: Di1 IPCP: Remove route to 62.155.xx.xx
*Jan 30 14:32:43.593: Di1 IPCP: Remove default route thru 62.155.xxx.xxx
*Jan 30 14:32:43.593: ppp_session_ntfy delete, topswidb Vi2, va Vi2, platform notify 0
*Jan 30 14:32:43.594: Vi2 IPCP: Event[DOWN] State[Open to Starting]
*Jan 30 14:32:43.594: Vi2 IPCP: Event[CLOSE] State[Starting to Initial]
*Jan 30 14:32:43.594: Vi2 LCP: Event[DOWN] State[Open to Starting]
*Jan 30 14:32:43.594: ppp_session_ntfy delete, topswidb Vi2, va Vi2, platform notify 0
*Jan 30 14:32:43.594: Vi2 PPP: Unlocked by [0x10] Still Locked by [0x0]
*Jan 30 14:32:43.594: Vi2 PPP: Free previously blocked vaccess
*Jan 30 14:32:43.594: Vi2 PPP: Phase is DOWN
*Jan 30 14:32:43.595: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Jan 30 14:32:43.597: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Jan 30 14:32:43.597: Vi2 PPP: Sending cstate DOWN notification
*Jan 30 14:32:43.604: Vi2 PPP: Processing CstateDown message
*Jan 30 14:32:43.609: PPPoE: Unexpected Event!. PPPoE switching Subblockdestroy called
*Jan 30 14:33:03.806: Sending PADI: Interface = GigabitEthernet0/0/0.7
*Jan 30 14:33:03.806: PPPoE VLAN CoS (pppoe_client_send_padi)=>GigabitEthernet0/0/0.7 :: cos=0x0
*Jan 30 14:33:03.897: PPPoE 0: I PADO R:ec13.db13.1cac L:c828.e555.4c21 7 Gi0/0/0.7
*Jan 30 14:33:05.854: PPPOE: we've got our pado and the pado timer went off
*Jan 30 14:33:05.854: OUT PADR from PPPoE Session
*Jan 30 14:33:05.854: PPPoE VLAN CoS (pppoe_client_send_padr)=>GigabitEthernet0/0/0.7 :: cos=0x0
*Jan 30 14:33:05.864: PPPoE 11: I PADS R:ec13.db13.1cac L:c828.e555.4c21 7 Gi0/0/0.7
*Jan 30 14:33:05.864: IN PADS from PPPoE Session
*Jan 30 14:33:05.866: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Jan 30 14:33:05.866: PPPoE: Virtual Access interface obtained.
*Jan 30 14:33:05.866: [0]PPPoE 11: data path set to PPPoE Client
*Jan 30 14:33:05.869: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Jan 30 14:33:05.870: Vi2 PPP: Sending cstate UP notification
*Jan 30 14:33:05.870: Vi2 PPP: Processing CstateUp message
*Jan 30 14:33:05.871: PPP: Alloc Context [7F7EDA2A42F8]
*Jan 30 14:33:05.871: ppp5 PPP: Phase is ESTABLISHING
*Jan 30 14:33:05.871: Vi2 PPP: Using dialer call direction
*Jan 30 14:33:05.871: Vi2 PPP: Treating connection as a callout
*Jan 30 14:33:05.871: Vi2 PPP: Session handle[84000005] Session id[5]
*Jan 30 14:33:05.871: Vi2 LCP: Event[OPEN] State[Initial to Starting]
*Jan 30 14:33:05.871: Vi2 PPP: No remote authentication for call-out
*Jan 30 14:33:05.871: Vi2 LCP: O CONFREQ [Starting] id 1 len 14
*Jan 30 14:33:05.871: Vi2 LCP: MRU 1492 (0x010405D4)
*Jan 30 14:33:05.871: Vi2 LCP: MagicNumber 0x290A3451 (0x0506290A3451)
*Jan 30 14:33:05.871: Vi2 LCP: Event[UP] State[Starting to REQsent]
*Jan 30 14:33:05.881: Vi2 LCP: I CONFREQ [REQsent] id 198 len 18
*Jan 30 14:33:05.881: Vi2 LCP: MRU 1492 (0x010405D4)
*Jan 30 14:33:05.881: Vi2 LCP: AuthProto PAP (0x0304C023)
*Jan 30 14:33:05.881: Vi2 LCP: MagicNumber 0x430AA9D8 (0x0506430AA9D8)
*Jan 30 14:33:05.881: Vi2 LCP: O CONFNAK [REQsent] id 198 len 9
*Jan 30 14:33:05.881: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 30 14:33:05.881: Vi2 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Jan 30 14:33:05.881: Vi2 LCP: I CONFACK [REQsent] id 1 len 14
*Jan 30 14:33:05.881: Vi2 LCP: MagicNumber 0x290A3451 (0x0506290A3451)
*Jan 30 14:33:05.881: Vi2 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Jan 30 14:33:05.889: Vi2 LCP: I CONFREQ [ACKrcvd] id 199 len 19
*Jan 30 14:33:05.889: Vi2 LCP: MRU 1492 (0x010405D4)
*Jan 30 14:33:05.889: Vi2 LCP: AuthProto CHAP (0x0305C22305)
*Jan 30 14:33:05.889: Vi2 LCP: MagicNumber 0x430AA9D8 (0x0506430AA9D8)
*Jan 30 14:33:05.889: Vi2 LCP: O CONFACK [ACKrcvd] id 199 len 19
*Jan 30 14:33:05.889: Vi2 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Jan 30 14:33:05.896: Vi2 PPP: Queue CHAP code[1] id[66]
*Jan 30 14:33:05.918: Vi2 PPP: Phase is AUTHENTICATING, by the peer
*Jan 30 14:33:05.918: Vi2 CHAP: Redirect packet to Vi2
*Jan 30 14:33:05.918: Vi2 CHAP: I CHALLENGE id 66 len 26 from "JUNOS"
*Jan 30 14:33:05.919: Vi2 LCP: State is Open
*Jan 30 14:33:05.919: Vi2 CHAP: Using hostname from interface CHAP
*Jan 30 14:33:05.919: Vi2 CHAP: Using password from interface CHAP
*Jan 30 14:33:05.931: Vi2 CHAP: O RESPONSE id 66 len 61 from "xxx@xxx"
*Jan 30 14:33:06.056: Vi2 CHAP: I SUCCESS id 66 len 4
*Jan 30 14:33:06.056: Vi2 PPP: Phase is FORWARDING, Attempting Forward
*Jan 30 14:33:06.057: Vi2 PPP: Phase is ESTABLISHING, Finish LCP
*Jan 30 14:33:06.057: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Jan 30 14:33:06.058: Vi2 PPP: No AAA accounting method list
*Jan 30 14:33:06.058: Vi2 PPP: Phase is UP
*Jan 30 14:33:06.059: Vi2 IPCP: Protocol configured, start CP. state[Initial]
*Jan 30 14:33:06.059: Vi2 IPCP: Event[OPEN] State[Initial to Starting]
*Jan 30 14:33:06.059: Vi2 IPCP: O CONFREQ [Starting] id 1 len 22
*Jan 30 14:33:06.059: Vi2 IPCP: Address 0.0.0.0 (0x030600000000)
*Jan 30 14:33:06.059: Vi2 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
*Jan 30 14:33:06.059: Vi2 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
*Jan 30 14:33:06.060: Vi2 IPCP: Event[UP] State[Starting to REQsent]
*Jan 30 14:33:06.066: Vi2 IPCP: I CONFREQ [REQsent] id 32 len 10
*Jan 30 14:33:06.066: Vi2 IPCP: Address 62.155.xxx.xxx (0x03063E9BF3CE)
*Jan 30 14:33:06.066: Vi2 IPCP: Accept the peer address 62.155.xxx.xxx
*Jan 30 14:33:06.066: Vi2 IPCP: O CONFACK [REQsent] id 32 len 10
*Jan 30 14:33:06.066: Vi2 IPCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
*Jan 30 14:33:06.066: Vi2 IPCP: I CONFNAK [ACKsent] id 1 len 22
*Jan 30 14:33:06.066: Vi2 IPCP: Address 80.xx.xx.xx (0x0306508B5E3D)
*Jan 30 14:33:06.066: Vi2 IPCP: PrimaryDNS 37.50.8.60 (0x81062532083C)
*Jan 30 14:33:06.066: Vi2 IPCP: SecondaryDNS 37.50.8.61 (0x83062532083D)
*Jan 30 14:33:06.066: Vi2 IPCP: O CONFREQ [ACKsent] id 2 len 22
*Jan 30 14:33:06.067: Vi2 IPCP: Event[Receive ConfNak/Rej] State[ACKsent to ACKsent]
*Jan 30 14:33:06.230: Vi2 IPCP: I CONFACK [ACKsent] id 2 len 22
*Jan 30 14:33:06.230: Vi2 IPCP: Address 80.xx.xx.xx (0x0306508B5E3D)
*Jan 30 14:33:06.230: Vi2 IPCP: PrimaryDNS 37.50.8.60 (0x81062532083C)
*Jan 30 14:33:06.230: Vi2 IPCP: SecondaryDNS 37.50.8.61 (0x83062532083D)
*Jan 30 14:33:06.230: Vi2 IPCP: Event[Receive ConfAck] State[ACKsent to Open]
*Jan 30 14:33:06.238: Vi2 IPCP: State is Open
*Jan 30 14:33:06.238: Di1 IPCP: Install negotiated IP interface address 80.xxx.xx.xx
*Jan 30 14:33:06.241: PPPoE : ipfib_encapstr prepared
*Jan 30 14:33:06.281: Di1 IPCP: Install default route thru 62.155.xx.xx
*Jan 30 14:33:06.281: Di1 Added to neighbor route AVL tree: topoid 796304859762330381, address 62.155.xx.xx
*Jan 30 14:33:06.281: Di1 IPCP: Install route to 62.155.xx.xx
*Jan 30 14:33:06.281: PPPoE : ipfib_encapstr prepared
*Jan 30 14:33:06.285: %SYS-5-CONFIG_P: Configured programmatically by process DDR Timers from console as admin on console
krevero
i solved the problem. It was the authentication type of pppoe. I used chap but the provider accepts just pap - unfortunately the debug of pppoe authentication didn't show any issues.
Thank you so much for you help, I really appreciate it @MHM Cisco World @Georg Pauwen
32 Replies 32
check security license is it activate or not
MHM
There is no sec license activated
sh license sum
Account Information:
Smart Account: <none>
Virtual Account: <none>
License Usage:
License Entitlement Tag Count Status
network-essentials_10M (ESR_P_10M_E) 1 IN USE
dna-essentials_10M (DNA_P_10M_E) 1 IN USE
the access list used for NAT does not look right. Make the changes marked in bold:
--> ip nat inside source list 1 interface Dialer1 overload
ip ssh version 2
ip sla 1
--> access-list 1 permit 192.168.1.0 0.0.0.255
--> access-list 1 permit 172.20.100.0 0.0.0.255
is it a difference to the extended access list 197?
I tried to remove the previous command - but it is not possible: "%Dynamic mapping in use, cannot remove"
The nice thing I solve other issues of NAT with other engineer and I read that there is restriction in NAT overload.
Now
Disable ip nat inside from interface
Change ip access-list 197 from using permit ip any any to
Permit ip 172.x.x.0 0.0.0.255 any
Remove other permit
Then
Enable ip nat inside in interface again
MHM
the extended access list contains a 'permit ip any any' which is not a good idea for NAT, since it translates everything including the interface(s).
krevero
well I've changed the access list 197 to:
40 permit ip 172.20.100.0 0.0.0.255 any
but I cannot even ping e.g. 8.8.8.8 from the router itself
post your full running configuration again with the changes you have made...
see attached file
192.168.1.0/24
What is this subnet? If it what you get from ISP?
If Yes then you dont need it in acl of NAT
Also when you modify acl of NAT
Do show access-list to check if it correct modify or not
MHM
This subnet ist just a local network for tests, there is only one client with a static ip connected to it. It shows "no internet connection" on this network. As i mentioned before, i cannot even ping from the router to the internet. So I ran out of troubleshooting ideas.
this is the output from show access-list
Extended IP access list 197
Extended IP access list CISCO-CWA-URL-REDIRECT-ACL
100 deny udp any any eq domain
101 deny tcp any any eq domain
102 deny udp any eq bootps any
103 deny udp any any eq bootpc
104 deny udp any eq bootpc any
105 permit tcp any any eq www
Extended IP access list meraki-fqdn-dns
Just one by one'
1- 192.168.1.0 can not use if the router dont have interface in this subnet
2- the NAT is working now only 172.20.100.0 since it add under acl of NAT
3- remove this new acl please
4- show ip route <- share this to see if pppoe interface get IP or not' if you see it get IP use it in ping to 8.8.8.8
MHM
1 - interface GigabitEthernet0/0/2 is the interface for this subnet
ip nat inside
negotiation auto
2 - thanks, i changed it to all subnets:
10 permit ip 172.20.0.0 0.0.255.255 any
 3 - which new acl do you mean?
4 - show ip route:
Gateway of last resort is 62.155.xx.xx to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 62.155.xx.xx
is directly connected, Dialer1
62.0.0.0/32 is subnetted, 1 subnets
C 62.155.xxx.xxx is directly connected, Dialer1
80.0.0.0/32 is subnetted, 1 subnets
C 80.139.xx.xxx is directly connected, Dialer1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0/0/2
L 192.168.1.1/32 is directly connected, GigabitEthernet0/0/2
CWA redirect ACL' where it apply?
4 - show ip route
The dialer 1 interface have two IP??
Shut and not shut the dialer interface to force it get one correct IP
Then use this IP in ping to 8.8.8.8 to check connect from your rputer to ISP to 8.8.8.8
MHM
