no internet with a static ip
pcfreak49
I have a question I want to configure a static ip on the wan interface but do not have internet more ?
cadet alain
what does the show ip route static output ?
You  probably had a default route from IPCP or DHCP but then now you need to define one.
Regards.
Alain
okay how do you solve that
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, GigabitEthernet0
      195.130.137.0/32 is subnetted, 1 subnets
S        195.130.137.3 [254/0] via 84.197.160.1, GigabitEthernet0
As Alain suggested, you might be having IP address from your provider via DHCP server.
Just to re-confirm, check output of command "sh ip interface brief"
If your see TFTP or DHCP in front of your WAN interface ( in your case Gi0 ), then you are getting IP from your ISP via DHCP.
So, if you want to have static IP, first you have to ask your ISP to provide you a static IP...
HTH,
Smitesh
PS: Please rate if helpful...
what do the wan interface via DHCP Static more if you do?
