Routeren on two wan interfaces
pcfreak49
I have a question I want on my 890 router between two wan interfaces routing using BGP?
8 Replies 8
vmiller
Level 7
Level 7
The product guide indicates that this is available.
feature navigator only lists the 891 and 892 for searching platforms/features
here is some reading:
http://www.cisco.com/en/US/docs/ios/iproute_bgp/configuration/guide/irg_basic_net.html
it is sometimes possible to bgp multiple times with other AS?
If you mean bgp sessions with different AS, yes.
I configured this, but now have no more internet how can you fix that?
have you ever had a connection (by any means) to your provider ?
you will need to post your configs, (scrubbed of any sensitive info) .
1. Does your router establish TCP connectivity with the ISP?
2. Are the AS numbers correct?
okay this is the config and may not runnning on the Internet
I have two static IP addresses on the wan interface but if I have two interface overload no more internet how can you solve that Gigibitethernet 0 ip address 81.83.91.138/21 Fast Ethernet 0 ip address 81.83.71.202/23
