07-31-2012 01:23 PM - edited 03-04-2019 05:07 PM
Appreciate some advise on one. I have a ppp multilink with QoS applied however I do not see any matches apart from in the standard class. The router is a 10k PE router running engineering special of 12.0-30 I have tried the following with no success:
- removed the QoS and reapplied
- created new QoS policy
- created new Class-maps
- i have tried configuring priority using "priority 128" and also "priority with police" as it should be on a 10k to use pxf at line rate
- I have bounced the multilink
- I have deleted the multilink and recreated
- I have deleted the multilink and recreated new multilink with different number
I have confirmed with verbose cache flow that traffic is reaching CE router marked as EF but if I ping the CE attached from within the vrf on another PE I never see any matches in the premium or enhanced classes outbound from the egress PE. All the traffic is falling within either standard or class default as show on "show policy-map int" and on a "show hardware pxf interface".
Any ideas appreciated I think I am hitting bug but can not see anything on bug tool kit. Below is config in questions:
class-map match-any PREMIUM
match dscp 46
class-map match-any ENHANCED1
match ip dscp 34 36 38
class-map match-any ICG_STANDARD
match ip dscp 10 12 14
policy-map POLICYOUT
class PREMIUM
priority
police 128000 16000 24000 conform-action transmit exceed-action drop violate-action drop
class ENHANCED1
bandwidth 256
random-detect dscp-based
random-detect dscp 34 22 66 1
random-detect dscp 36 14 44 1
random-detect dscp 38 7 22 1
class STANDARD
bandwidth 1533
random-detect dscp 10 171 513 1
random-detect dscp 12 103 342 1
random-detect dscp 14 52 171 1
interface Multilink1
ip vrf forwarding CUSTOMER
ip address 192.168.1.1 255.255.255.252
no ip redirects
no ip directed-broadcast
no ip proxy-arp
ip pim sparse-mode
ppp multilink
ppp multilink fragment-delay 8
ppp multilink interleave
multilink-group 3002231
service-policy input POLICYIN
service-policy output POLICYOUT
end
interface Serial3/0/1.1/3/5/1:0
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
end
07-31-2012 01:47 PM
Just to begin with, since you have a single interface, why are you using MLPPP ?
07-31-2012 03:25 PM
Hi, thanks for responding. This is to allow us to add further serials as bandwidth upgrade at a later date with no service disruption I believe.. I will have to configure without the multilink if I am unable to get the other classes to match.
07-31-2012 04:01 PM
Yes I would start without multilink first and then provide the various show output that you mentioned, as well the show interface for that one.
08-01-2012 03:01 AM
Got to the bottom of this. The premium had been configured with 'match dscp 46' I amended to 'match ip dscp 46' and all working.
Adding the 'ip' to match means it is specific to ipv4. If not used (like it was originally configured) it should match both ipv4 and ipv6 but this was not happening. Smells like a bug
08-01-2012 02:51 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I'm unfamiliar with the 10K series, but was just wondering whether any type of "trust" has to be configured on ingress interfaces (similar to 6500s).
