no mpls ip propagate-ttl forwarded
daniel-nilsson
I have a lab with some  asr901 and c2800.
I am trying to hide the WAN from the customers.
mpls ip propagate-ttl (default)
Effect: TTL 253, traceroute showing the 5 hops in the WAN
Effect: TTL 253, traceroute showing the 5 hops in the WAN,(exactly the same results).
What am i missing here?
/Daniel
10 Replies 10
Ajay Raj
Are you trying this in MPLS Edge router
I have a pc pinging anouhter PC at the other end of the WAN lab cloud.
These pc:s are connected directly on asr901 routers that runns MPLS.
Hello Daniel,
As I understand it, is that this command needs to be applied on all LSR's in the mpls switch path
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
You can put this command in both the edge routers in Config mode.
no mpls ip propogate-ttl.
This will work for sure. Please reply
Hi and thaks for your replay
This command is configured on all LSR:s on the path and then rebooted just in case.
I have tryded without the "forwarded" option but still the same effekt.
The effect that i am looking for is that the icmp replay chould have ttl like 254/253 and traceroute chould have about 1 or 2 hops, not 5.
I get ttl 253 that may be correct but i dont whant to see the the WAN hops.
If i change the accessports to the pc:s so it is not a part of a vrf, so it just uses the global routing, the ttl become 250 like it would be with ordinary routing.
Hi Daniel,
The command "no mpls ip propagate-ttl forwarded" will hide all LSRs in the core except for the ingress and egress LSR.
Can you please share trace o/p before and after disaling ttl propogation
milan.kulik
Level 10
Level 10
I think i need to go for a TAC on this one, it could be a "feature" on these new ASR901.
The ASR901 has no support for ths feature, but in the future it will.
