No network-clock-participate command
amiralisetoudeh
Hello everyone,
I'm trying to configure a VWIC2-1MFT-E1, and under the controller config when I try to enter pri-group timeslots 1-31, it says please configure network-clock-participate wic 0 first.
So when I go to global config and enter net? , I only get 'netbios' as an available command. It seems like network-clock-participate isn't even available.
The router I'm working on is an 1841.
I'd greatly appreciate any help on this matter!!
-Ali
5 Replies 5
JORGE RODRIGUEZ
Level 10
Level 10
try complete keyword network
e.i
router(config)#network ?
you should get three options
network-clock-participate, network-clock-select , and network-clock-switch
then choose
router(config)#network-clock-participate wic 0
let us know how it works out
Rgds
Jorge
Jorge Rodriguez
Probably i would suspect the platform support!
1841 may not support this VWIC2. To be clear u may post the "sh diag" output
Cheers!
Thanks for the response Jay.
Here's the output for show diag:
Slot 0:
C1841 2FE 2SLOT Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time 13:39:41 ago
EEPROM contents at hardware discovery:
Chassis MAC Address : 0022.55b5.d514
MAC Address block size : 34
PCB Serial Number : FOC12276222
Hardware Revision : 7.0
Part Number : 73-8191-08
Board Revision : D0
Top Assy. Part Number : 800-23434-06
Deviation Number : 0
Fab Version : 04
CLEI Code : IPM7W00CRA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : CISCO1841
Version Identifier : V05
Processor type : 86
Chassis Serial Number : FTXXXXXXXXX
EEPROM format version 4
EEPROM Contents (hex) ... omitted
WIC/HWIC Slot 0:
VWIC2-1MFT-G703 - 1-Port RJ-48 Multiflex Trunk - T1/E1 & G.703
Hardware Revision : 0.0
Top Assy. Part Number : 800-24918-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC12200901
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-G703
Version Identifier : V01
EEPROM contents (hex): omitted
I should probably let you in on the big picture. I've sent an 1841 router to Mexico, and the line there is an E1 R2 modified.
Looking up the requirements for configuring my controller on Cisco, I've found the following:
Mexico Telmex Modified
controller E1 0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 1
country telmex
category 2
answer-signal group-b 1
They've told me it's supposed to be channel-group, but I trust Cisco's config... (I've already tried channel-group and the serial interface gets created but it stays up/down).
So I want to try the ds0 and pri groups but when I enter the commands, it says enter the network-clock-partitipate wic 0 command first. Well, unfortunately that command isn't even available for me in Global Config mode.
The version of my IOS is:
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(21), REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jul-08 00:16 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Hopefully I've provided enough info...
Thanks again!!
Ali
Thanks for the reply, Jorge.
I've already tried what you suggested. I've even tried blindly entering the command even though it's not available, but no good.
I'm sure it's not platform specific, because I've seen configs on 1800's that have this on them.
Ali
amiralisetoudeh
Well I guess I have the issue resolved, although I had to take a different route.
I used channel-group to bring my E1 up, but I still don't know why I don't have the network-clock-participate command available.
Thanks for the responses.
Ali
