No pass service PPPoE
EveEri
Hello
At the moment I am trying to send services PPPoE to destination BRAS but the clients not connect. I checked of vc and tunnel up. This is sent through a 10G interface . The module is 7600-ES20-10G3CXL. Is there some limitation with the line card?
Version 12.2(33)SRE15a
Cisco7609
interface Vlan2
description ### PPPOe FB BRAS VLAN 2 ###
mtu 1900
no ip address
xconnect 20.1.2.100 32 encapsulation mpls pw-class PPPOE_PE_BRAS
end
pseudowire-class PPPOE_PE_BRAS
encapsulation mpls
preferred-path interface Tunnel32
interface Tunnel32
description PPPOE_PE_BRAS
ip unnumbered Loopback100
tunnel mode mpls traffic-eng
tunnel destination 20.1.2.100
tunnel mpls traffic-eng path-option 5 explicit name PE-P1-BRAS
tunnel mpls traffic-eng path-option 10 dynamic
tunnel mpls traffic-eng record-route
tunnel mpls traffic-eng fast-reroute
ip rsvp bandwidth 800000
ip explicit-path name PE-P1-BRAS enable
next-address 10.x.x.x
Giuseppe Larosa
Hello EveEri,
is the pseudowire service up ?
show mpls l2transport
is the  TE tunnel 32 up ?
What if you put the xconnect command under a physical interface of the module  instead of using an SVI?
Hope to help
Giuseppe
