SSH disabled on WS-C2960C-8PC-L
Dmitriy Ivanov
Bought switch via Amazon.
c2k9-ff-05-1#sh ver
Cisco IOS Software, C2960C Software (C2960c405-UNIVERSALK9-M), Version 15.2(3)E2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 21-Jul-15 13:37 by prod_rel_team
ROM: Bootstrap program is C2960C boot loader
BOOTLDR: C2960C Boot Loader (C2960c405-HBOOT-M) Version 12.2(55r)EX9, RELEASE SOFTWARE (fc1)
c2k9-ff-05-1 uptime is 17 minutes
System image file is "flash:/c2960c405-universalk9-mz.152-3.E2.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C2960C-8PC-L (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1911Z3JQ
Last reset from power-on
2 Virtual Ethernet interfaces
8 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 88:90:8D:12:B8:80
Motherboard assembly number     : 73-13529-03
Power supply part number        : 341-0407-01
Motherboard serial number       : FOC19111SH0
Power supply serial number      : DCB190520H9
Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C2960C-8PC-L
System serial number            : FOC1911Z3JQ
Top Assembly Part Number        : 800-35234-01
Top Assembly Revision Number    : K0
Version ID                      : V01
CLEI Code Number                : CMMGC00ARA
Hardware Board Revision Number  : 0x01
Switch Ports Model                     SW Version            SW Image
*    1 10    WS-C2960C-8PC-L           15.2(3)E2             C2960c405-UNIVERSALK9-M
Configuration register is 0xF
We see it is K9- ssh should be included.
This is in config:
line con 0
 password ***
 login local
 stopbits 1
line vty 0 4
 access-class 10 in
 password ***
 login local
 transport input all
line vty 5 15
 login
 transport input all
end
as per manual I done this:
  1. enable
  2. configure terminal
  3. hostname hostname
  4. ip domain-name domain_name
  5. crypto key generate rsa
  6. end
  7. show running-config
and after all these troubles  we have this:
c2k9-ff-05-1#sh ip ssh
SSH Disabled - version 1.5
%Please create RSA keys to enable SSH (and of atleast 768 bits for SSH v2).
Authentication methods:publickey,keyboard-interactive,password
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
MAC Algorithms:hmac-sha1,hmac-sha1-96
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 1024 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): NONE
c2k9-ff-05-1#
Any advise?
Thanks a lot !
2 Accepted Solutions
10 Replies 10
For a long time, the "crypto key generate" command by default generated 512 bit keys which is too small for SSH. I thought, the default was increase to 1024 Bit some time ago, but as you are running a quite recent IOS, probably the default was not changed for your platform.
For enabling SSH also see the following document:
https://supportforums.cisco.com/document/12338141/guide-better-ssh-security
generated key with 1024 modulus- same thing- it says:
I tried both ssh v1 and v2- with different size of key- same result - ssh disabled.
see this:
c2k9-ff-05-1(config)#crypto key generate rsa modulus 1024
% You already have RSA keys defined named c2k9-ff-05-1.undp.org.
% They will be replaced.
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 3 seconds)
c2k9-ff-05-1(config)#do sh ip ssh
Thank you!
Have you tried using the labeled keys?
YES YES AND YES!
You article is really works! Thanks a lot!!!!
c2k9-ff-05-1(config)#crypto key generate rsa label SSH-KEY modulus 1024
% You already have RSA keys defined named SSH-KEY.
[OK] (elapsed time was 2 seconds)
c2k9-ff-05-1(config)#ip ssh rsa keypair-name SSH-KEY
SSH Enabled - version 1.99
Thanks !!!!!
@Dmitriy Ivanov wrote:
YES YES AND YES!
Karsten- thank you- following your article- will let you know how it goes.
Interesting observation:
On 4500 switch it says
c4k5#sh ip ssh
ssh-rsa AAAA..ke....
as you see on another switch we have IOS KEYS in SECSH format and it is working there...
my assumption is that
"crypto key generate rsa" _must_ create the key in SECSH but it does not happen...
It just says that the router doesn't have a key to use. The format is always the same.
