No WAN Connection through inside interface
sharpy84_123
Apologies in advance for my lack of knowledge on this subject, I have a cisco 2800 router running software version 12.4.
I am attempting to gain a WAN connection for clients on the LAN behind the router, the router will sit behind the primary router and assigned a external IP from a range on a leased line connection. I have tested the theory by putting my laptop behind the router assigning it the external IP, subnet mask and default gateway with 8.8.8.8 and 4.2.2.2 as the DNS and I successfully got a WAN connection and was able to browse the web.
I attempted the same with the router but at the moment am struggling getting out on to the internet when behind the 2800. Maybe I am missing something blatantly obvious, here's my running config. It would be hugely appreciated if someone could give me a nudge in the right direction.
When I run a test on the external interface it completes successfully, however when I run a test on internal interface it returns "checking exit interface select user-specified option or add a host specific/network specific/default route through this interface and retest connection"
Here is my running config below
Thanks in advance.
Building configuration...
Current configuration : 3765 bytes
version 12.4
hostname ************
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 ************
enable password ************
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip name-server 8.8.8.8
ip name-server 4.2.2.2
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-2983870642
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2983870642
 revocation-check none
 rsakeypair TP-self-signed-2983870642
crypto pki certificate chain TP-self-signed-2983870642
 certificate self-signed 01
        quit
username ******** privilege 15 password 0 ********
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 192.168.110.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 description $ETH-WAN$
 ip address 88.88.88.88 255.255.255.240
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1/0
 switchport mode trunk
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
 no mop enabled
interface ATM0/0/0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 88.88.88.89
ip http server
ip http authentication local
ip http secure-server
ip nat pool IP_Pool 192.168.110.1 192.168.110.10 netmask 255.255.255.0
ip nat inside source list 2 pool IP_Pool overload
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.110.0 0.0.0.255
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.110.0 0.0.0.255
snmp-server community public RO
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
line con 0
line aux 0
line vty 0 4
 password **************
 transport input telnet ssh
scheduler allocate 20000 1000
end
Hello
Is this the running config of the primary router or the router that is behind it - ( i assume its the primary?)
If so what port are you attaching the "other" router siting behind the primary  and can you post the running config that router also.
res
Paul
Kind Regards
Paul
Hi Paul
Thanks for the prompt reply, I have managed to correct the issue by adding the line.
ip routing
I am not sure what this has done but appears to have rectified my problem.
FYI this is the router that will sit behind the primary router.
Thanks again for your reply, is very much appreciated.
Bizarre! considering IP Routing is automatically enabled in the Cisco ios. Even if it was disabled it should have showed as 'no ip routing' in the config.
Essentially, this command enables the router to 'route' IP packets :)
