DMVPN and iWAN Cisco technology. On Cisco ASR1001-X series router, is it possible to configure two DMVPN domains.
8-10 remote sites will be on staying on existing open-standard non-cisco for IPSec connectivity and the rest of the sites will be converted over Cisco DMVPN/iWAN with head-end DMVPN router ASR at the data center, and ISR series routers will be at the remote locations.
My challenge is how I could continue to support non-cisco VPN IPSec remote sites connectivity to data center where I will be replacing the existing non-cisco VPN Hub router with Cisco ASR1001-X DMVPN router.
I understand that none of the non-Cisco sites will be able to take advantage of iWAN, but can they still be terminated over the same Cisco ASR1001-X DMVPN router.
