CB Traffic Shaping: peak Vs Average
e.ciollaro
Level 4
Level 4
here a question about practical difference between shape average and shape peak. In my understanding the difference between average and peak is that "peak" put Bc+Be token in the tocken bucket every Tc while "average" put just Bc token. By default Be is equal to Bc. So I make the following sample config; what I expect is that they do exactly the same shaping:
policy-map SHAPE
 class class-default
  shape peak 10000000  150000
policy-map SHAPE2
 class class-default
  shape average 20000000 300000 0
I applied the policy and this is the result:
R1(config-pmap)#do sh policy-map int
 FastEthernet0/0
  Service-policy output: SHAPE
    Class-map: class-default (match-any)
      1296 packets, 116083 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average          Byte   Sustain   Excess    Interval  Increment
             Rate                      Limit  bits/int       bits/int       (ms)      (bytes)
         20000000/10000000  37500  150000     150000        15        37500
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active  Depth      Delayed   Delayed   Active
        -               0         1296      116083          0         0         no
 FastEthernet0/1
  Service-policy output: SHAPE2
      244 packets, 20629 bytes
      Match: any
      Traffic Shaping
         20000000/20000000        7500  300000         0              15        37500
        -      0         244       20629     0         0         no
As expected Target rate is the same, and Tc and bucket size are also the same. So I my understanding this two config would shape a traffic flow in the same way. Is it correct ?
Second question: which is the default policy for delayed traffic: FIFO o WFQ ?  In IOS documentation I read:
When packets are placed in a queue, the default queueing mechanism used is weighted fair queueing (WFQ). However, with Class-Based Traffic Shaping, class-based WFQ (CBWFQ) can be configured as an alternative queueing mechanism.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_regpkt/configuration/15-mt/qos-regpkt-15-mt-book/qos-regpkt-cls.html#GUID-3C890022-49C2-424B-827F-6090ED50FF81
But in "CCIE Routing&Switching Certifciation Guide" (Odom, Healy, Donohue, 4th Edtion), pg 1615:
Example 14-2 in the previous section shows default settings for queuing for the interface software
queues (WFQ) and for the shaping queue (FIFO)
Which is true ?
Bye,
enrico
0 Replies 0
