Non-working NAT on Catalyst 9410R
kz-support
Hello
We have a problem with NAT translation on the Catalyst 9410R (IOS-XE 17.6.4) - NAT  not working but pings do.
Part of config is below:
ip nat inside source list 1 interface Vlan1111 vrf MMM overload
interface Vlan1111
ip vrf forwarding MMM
ip address dhcp
ip nat outside
interface Vlan666
description *** MMM ***
ip address 172.25.0.1 255.255.255.0
ip nat inside
Standard IP access list 1
    10 permit 172.25.0.0, wildcard bits 0.0.0.255 (19072 matches)
We tryed to configure static IP on the outside interface, but problem remains the same.
Jul 10 14:58:26.255 MSK: NAT: New Inside Entry: couldn't allocate port 50353 for 172.16.20.72 Protocol: 17
Jul 10 14:58:26.255 MSK: NAT: translation failed (A), dropping packet s=172.25.4.77 d=185.128.196.254
Jul 10 14:58:26.255 MSK: NAT: New Inside Entry: couldn't allocate port 49165 for 172.16.20.72 Protocol: 17
Jul 10 14:58:26.350 MSK: NAT: New Inside Entry: couldn't allocate port 50935 for 172.16.20.72 Protocol: 17
Jul 10 14:58:26.350 MSK: NAT: translation failed (A), dropping packet s=172.25.4.11 d=8.8.8.8
Jul 10 14:58:27.105 MSK: NAT: New Inside Entry: couldn't allocate port 51554 for 172.16.20.72 Protocol: 17
Jul 10 14:58:27.105 MSK: NAT: translation failed (A), dropping packet s=172.25.4.143 d=8.8.8.8
Jul 10 14:58:27.186 MSK: NAT: New Inside Entry: couldn't allocate port 56192 for 172.16.20.72 Protocol: 17
7 Replies 7
Hello
Can you elaborate a little on the current topology, inter-vrf nat on XE can also be accomplished using VASI network translation depending if those 9400s support it.
When you sate static routing, is this within the VRF rib towards the global route table (GRT), Maybe post a diagram on your current setup?
Kind Regards
Paul
Add to your NAT
Match-in-vrf
And check again
MHM
there's no such option
 ip nat inside source list access-list-number pool pool-name [vrf vrf-name [match-in-vrf]] <<- this only for ASR run IOS XE not for car9K
MHM
MHM
VRF-aware NAT supports only VRF to Global translation of IP addresses. VRF to Global translation is between a NAT inside interface that is associated with a specific VRF and a NAT outside interface that is associated with the global VRF. Intra-VRF NAT translation (which involves the NAT-inside and NAT-outside interfaces of the same specific VRF) and Inter-VRF NAT translation (which involves NAT-inside and NAT-outside interfaces that are associated with different VRFs) are not formally supported. NAT behavior is undefined in such unsupported scenarios. We recommend that you deploy only the VRF to Global NAT translation in your network.
it not support in cat9000 platform
sorry for this bad news
you need to change one side to global to work
MHM
Hello
@kz-support wrote:
Hello
Post a topology diagram and maybe the run cfg of the rtr please
Kind Regards
Paul
Giuseppe Larosa
Hello @kz-support ,
given your ACL definition :
your interface Vlan 666
configuration
in the logs we see that the source IP address  is out of 172.25.0.0/24
if you have other subnets downstream the switch that need to be NATTed you have to change your ACL 1 used in the NAT to accomodate for their translation to happen.
Hope to help
Giuseppe
