Noob question regarding restoring a router config
BHPCI_2
I have a 3845 router and the only backup I have is a 'show run' that was  copied and pasted into notepad.  If I try to paste this in to the router, it  only merges with the running config instead of replacing it.  Using my TFTP  server, can I just do a 'copy tftp startup-config' naming the backup.txt file as  the soiurce file or does it need to be in a format other than .txt?  Thanks in  advance.
Hi ,
Via tftp , will be enought : copy tftp://ip/file nvram:startup-config,then reload.
Or configure network tftp://ip/file
It doesnt metter the extension of the file , but it has to be a txt file - as you save it via notepad.
Dan
Hi ,
Dan
