AIM-ATM replacement for ISR G2 ?
hakotheman
Customer is using AIM-ATM AIM with a VWIC2-1MFT-T1/E1 card installed, and using the E1s in ATM mode.
They have recently migrated to ISRG G2, but; ISR G2 (2911) dosen't support AIM Modules, and there is no relevant module for ATM.
So is there anything we can do to accomplish same functionality on ISR G2 ?
Thanks&Regards
paolo bevilacqua
You understanding is correct, there is nothing.
Ask SP to migrate to regular E1, you will gain in bandwidth, and save hardware.
