06-02-2005 06:53 PM - edited 03-03-2019 09:44 AM
28xx cisco router with 500 users behind it what normal number of nat translations?
I have 18 vlans. One vlan has 10000 nat translations with the others at 10-300. Damn virus.
06-02-2005 09:59 PM
10000 NAT translations seems high indeed. You could try to rate limit your translations, check the document below for details.
How do you have your NAT implemented (e.g. PAT) ?
Rate Limiting NAT Translation
GP
06-02-2005 10:12 PM
yes pat
I went with
ip nat translation timeout 600
ip nat translation tcp-timeout 600
ip nat translation udp-timeout 600
I can't login to that webpage by the way.
06-03-2005 01:27 AM
router(config)#ip nat translation max-entries ?
<1-2147483647> Number of entries
all-vrf Specify maximum number of NAT entries for each vrf
vrf Specify per-VRF NAT entry limit
06-03-2005 01:49 AM
Try the URL without the "partner/":
Most of CCO is available to the public, but unfortunately if we access the page using a logged-in window, then the resulting URLs are restricted to registered users. But most of them are available to the public, just by removing the "partner/" or "customer/" part of the URL.
Kevin Dorrell
Luxembourg
06-03-2005 01:51 AM
wouldn,t it be better investigating the cause instead of the results ?
You most certainly must be able to point out the cause by just having a look at these translations with "show ip nat translation"
Otherwise cache flow can tell you a lot more about the problem.
