not able reach router interface from l3 switch connected l2 switch
jsremi001
I am not able to reach router interface from the l3 switch connected l2 switch. The topology is R2 <--> L3 Switch <--> L2 switch.
The config:
R2:
interface FastEthernet0/0
ip address 10.2.2.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
router eigrp 1
network 10.2.0.0 0.0.255.255
auto-summary
ip route 10.20.20.0 255.255.255.0 10.2.2.2
L3 Switch:
interface Ethernet0/0
no switchport
ip address 10.2.2.2 255.255.255.0
interface Ethernet0/1
switchport access vlan 2
switchport mode access
interface Ethernet0/2
switchport trunk allowed vlan 2
switchport mode trunk
interface Vlan1
no ip address
interface Vlan2
ip address 10.20.20.1 255.255.255.0
router eigrp 1
network 10.20.0.0 0.0.255.255
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.2.2.1
L2 switch:
interface Ethernet0/3
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
IP address 10.20.20.2 255.255.255.0
no IP route-cache
interface Vlan3
no IP address
no IP route-cache
shutdown
ip default-gateway 10.20.20.1
7 Replies 7
add 'no auto-summary' to the EIGRP configs on both the router and the L3 switch...
done. still not reachable. It is not because of auto-summary. Refer the attached pic for topology.
Seb Rupik
Hi there,
Dome the L3 switch have routing configured?:
ip routing
cheers,
Seb.
Please attach config for all devices. Please do:
show cdp neighbors on all three devices.
show vlans | i active on layer three and layer 2 switch
show int "interface" trunk on all trunk interfaces
show ip route on all three devices
Please mark helpful posts
pieterh
in the configuration snippet I see no "ip routing" statement ??
Ok. I am trying this from GNS3 using IOU images. They are accepting the ip routing command but the same not appearing in the sh run result. any suggestions?
check version and/or license if routing feature is enabled for this switch
