10-21-2018 05:41 PM - edited 03-05-2019 10:59 AM
Hello Everyone! Can someone help me? Is an annoying problem that I cannot find.
The part of the topology that is having problem is this:
The rest of the topology is find.
I practice this in Packet Tracer and it works but when I do the implementation on real equipment do not work well.
Those L3 Switches are sharing routing information about the Lans directly connected to them through Vlan 99 Interface. All Fine. All the routing tables have the correct info.
When I connect the ASA 5510 8.0(2) and configure it to share Routing Info with the Switch AA, they create Neighbor Relationship but do not share routing information, i skip that with static routes, but, when I try to ping from the host connected to the ASA to outside of his own LAN cannot get a reply. When I ping from the ASA I get replies. On the ASA I use an ACL with Permit Any Any Statement in the Inside Interface and the Outside Interface in the 2 directions, the ACL get some matches but still not getting a reply. Also put the 2 interfaces on the same security level and use the command to permit the communication between the interfaces.
I attach the configuration files of the ASA and the Switch A, maybe someone can help to figure it out what is wrong.
New Info:
I notice that the Static route that is in the ASA is wrong, I put the outside interface IP and not the next Hop IP ( Vlan10 Interface). This not explain why eigrp is not sharing routes.
Also, I was thinking about NAT Control, I do not know if it is enable by default, when I have access I will modify the route and configure the NAT Control exception.
10-21-2018 08:40 PM
John
10-21-2018 11:00 PM
10-21-2018 11:11 PM
If you are having issues pinging from inside to outside through the router, then the problem could be with the routing. Since you have installed a static route on the ASA, you might need to configure a static route on switch AA for the network behind the ASA.
John
10-22-2018 07:40 AM
10-21-2018 08:46 PM
off the ASA, can you paste:
show route eigrp
and
show eigrp neighbors
10-21-2018 11:03 PM
