Not able to convert port on Cisco 8200, c-nim-8t
Rohit Patil
When trying to issue "no switchport" it gives error "port not convertible".
I am using dna advantage add on to network advantage licence.
I don't think an additional licence is required.
Cristian Matei
    You get that error message, because that's a layer 2 port only, thus command is not supported. With this specific module, only some ports can be layer 2 or layer 3, all other ports being just layer 2: https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-series-gigabit-ethernet-lan-wan-modules-ds.html
Best,
Cristian.
Thanks for the reply @Cristian Matei .
So, What could be the solution? how do I convert entire module into layer 3, I tried
" int range gi0/1/0-0/1/
No switchport "
Still didn't worked.
Do I have to make use of svi or, irb/bvi for routing from each port from my entire module
