01-05-2018 03:04 AM - edited 03-05-2019 09:43 AM
I have some unused routers being kept in the datacenter. I thought of making use of it and create a lab.
Now in that I have one Cisco2921 router which was configured by someone but he is no longer in our team. Now when i connect to the router through console. It gives the below output only all time. I am not able to go into rommon where i can change the confreg. If someone could help me, it would be of great help as to how to break in :
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x3bcb49c
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
HWIC Slot 0 0x00200000
Onboard devices &
buffer pools 0x022F6000
TOTAL: 0x024F6000
Rounded IOMEM up to: 40Mb.
Using 7 percent iomem. [40Mb/512Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 01-Jun-11 16:54 by prod_rel_team
Image text-base: 0x2100AB58, data-base: 0x25954280
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL15221083
1 FastEthernet interface
3 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
in-nso-banga-ce-05 line 0
User Access Verification
Tacacs not reachable - Enter local username:
Solved! Go to Solution.
01-05-2018 03:30 AM
Hi Ankit,
The trick is to send the Break sequence while the router is booting up and the # symbols are being displayed on the screen. However, every software may have a different key combination to send the break sequence. The following document lists the key combinations to send a Break sequence for some of the terminal software emulators:
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/12818-61.html
For PuTTY (which is not described in the document above), the combination is <Ctrl><Break> as well, and you should also try sending it from the Special Commands menu: Right-click on the title bar of a PuTTY window, select Special Commands, and then choose sending the Break. If you are using a different terminal software, it should also have an option of sending the Break by choosing a proper function from the menu.
Make sure that you are connected to the CON port, not to the AUX port.
Best regards,
Peter
01-05-2018 03:27 AM
02-23-2020 08:20 PM
01-05-2018 03:30 AM
Hi Ankit,
Best regards,
Peter
01-09-2018 07:26 AM
