Not able to ping server IP from Switch but server mac is showing on MAC table
tuhinbhowmick
Hi All,
Not able to ping a server directly connected from Switch via Patch Panel but able to see the MAC address of the same server under Switch MAC table. Also, the same server IP is pinging from other Switches as well on Network.
Clear the ARP cache but without any luck, shut / no shut that particular port as well. Still , not able to ping the server IP from the switch on whhich it is directly connected.
Need help from expert.
TB
ktwaddell
what is the IP address of the server you are trying to ping
what is the IP address of the switch you can't ping from
and
what is the IP address of a switch you CAN ping the server from?
Kev
ktwaddell
and
Kev
server ip : 10.203.101.67 want to ping from Sw 10.203.96.11, where it is connected.
Sw IP : 10.203.96.11       from this sw we are unable to ping server 10.203.101.67.
Sw IP : 10.203.96.12      from this sw, I am able to ping the server 10.203.101.67.
let me know if you require any further information  on the same.
TB
I suppose the switch is L2 only?
What are the subnet masks used?
I suppose the switch IP address and the server IP address are NOT in the same subnet?
So what is the default gateway configured on the switch?
What does traceroute to the server show?
Can you compare with the output from the switch which Pings successfully?
HTH,
Milan
