Not able to reach neighbour even after link restoration
Udupikrishna091
Hi Guys,
               I have a problem where I have 3845 router and c3845-advsecurityk9-mz.124-24.T5.bin dis is the IOS running on it and there's a back up BRI interface for the serial. Now if my serial link goes it normally goes to my BRI, once we had a time where the BRI was also down and when we restored back the Serial link we were still not able to reach the other side. We are using OSPF routing to reach the destination. When this happens and when we reboot this router we are able to reach the destination. sometimes we are able to reach it when we remove ospf and use static and  now if we put back the ospf routing the link comes back, this happens again and again, need urgent help on this, any advice would be helpful.
Krishna
Reza Sharifi
Hi Krishna,
Can you post your config (sh run)?
Hi Reza,
The Below the config, We actually did a IOS upgrade to the above mentioned version recently after which we actually started getting this problem, but it's a latest ver to which upgraded and I didnt find any kind of bugs
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname Shimoga
boot-start-marker
boot system flash:c3845-advsecurityk9-mz.124-24.T5.bin
boot-end-marker
card type e1 4
logging message-counter syslog
logging buffered 4096
no logging console
enable secret 5
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 10 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
group tacacs+
aaa accounting commands 10 default
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa session-id common
no network-clock-participate slot 4
dot11 syslog
no ip source-route
no ip cef
no ip bootp server
no ip domain lookup
no ip ips notify log
isdn switch-type basic-net3
username netsol privilege 10 password 7
username Admin password 7
username rmcyard password 7
username badravathi password 7
username Sagar password 7
username Harihara password 7
username chikmagalur password 7
username nehruroad password 7
username Tarikere password 7
username Thirthahalli password 7
username Honnali password 7
username MLR-Core password 7
username kblnoc01 privilege 15 password 7
username kblnoc03 privilege 15 password 7
username kblnoc04 privilege 15 password 7
username kblnoc07 privilege 15 password 7
username Kannan password 7
username Jeet password 7
username kblnoc08 privilege 15 password 7
username kblnoc09 privilege 15 password 7
username kblnoc10 privilege 15 password 7
username kblmdl privilege 15 password 7
username Kadur password 7
archive
log config
  logging enable
  logging size 500
  notify syslog contenttype plaintext
  hidekeys
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
crypto isakmp key 6 ba@h*!h#8 address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set KARBANK esp-3des esp-md5-hmac
crypto map SHMMDL-1 10 ipsec-isakmp
set peer 172.17.253.6
set peer 172.17.253.10
set peer 172.17.253.14
set peer 172.17.253.18
set peer 172.17.253.22
set peer 172.17.253.26
set peer 172.17.253.30
set peer 172.17.253.34
set peer 172.17.253.38
set peer 172.17.253.42
set peer 172.17.253.46
set peer 172.17.253.50
set peer 172.17.253.54
set peer 172.17.253.58
set peer 172.17.253.62
set peer 172.17.253.66
set peer 172.17.253.70
set peer 172.17.253.74
set peer 172.17.253.86
set peer 172.17.253.90
set peer 172.17.253.94
set peer 172.17.253.98
set peer 172.17.253.102
set peer 172.17.253.106
set peer 172.17.253.114
set peer 172.17.253.118
set peer 172.17.253.78
set peer 172.17.253.82
set peer 172.17.253.110
set transform-set KARBANK
match address IPSEC
qos pre-classify
crypto map karnatakabank 10 ipsec-isakmp
set peer 172.30.1.21
set peer 172.30.2.21
match address MDLIPSEC
controller E1 4/0
shutdown
framing NO-CRC4
pri-group timeslots 1-31
description *** BSNL PRI 08182-225402 ***
controller E1 4/1
framing NO-CRC4
channel-group 1 timeslots 1
channel-group 2 timeslots 2
channel-group 3 timeslots 3
channel-group 4 timeslots 4
channel-group 5 timeslots 5
channel-group 7 timeslots 7
channel-group 8 timeslots 8
channel-group 9 timeslots 9
channel-group 10 timeslots 10
channel-group 11 timeslots 11
channel-group 12 timeslots 12
channel-group 13 timeslots 13
channel-group 14 timeslots 14
channel-group 15 timeslots 15
channel-group 16 timeslots 16
channel-group 17 timeslots 17
channel-group 18 timeslots 18
channel-group 19 timeslots 19
channel-group 20 timeslots 20
channel-group 21 timeslots 21
channel-group 22 timeslots 22
channel-group 23 timeslots 23
channel-group 24 timeslots 24
channel-group 25 timeslots 25
channel-group 26 timeslots 26
channel-group 27 timeslots 27
channel-group 28 timeslots 28
channel-group 29 timeslots 29
channel-group 30 timeslots 30
class-map match-any VC
match ip precedence 7
match ip precedence 6
match ip precedence 4
class-map match-all FINACLE-2
match access-group name NAV
class-map match-all FINACLE-1
match access-group name FIN
policy-map FINACLE
class FINACLE-1
  set precedence 1
    shape average percent 60
class FINACLE-2
    bandwidth remaining percent 20
    shape average percent 20
class class-default
    bandwidth remaining percent 40
    shape average percent 40
policy-map VideoConf
class VC
    priority 1024
class class-default
    fair-queue
interface Tunnel1
description **** FOR VSAT BACKUP ****
ip address 172.30.4.22 255.255.255.252
ip ospf mtu-ignore
keepalive 5 10
tunnel source 10.103.170.210
tunnel destination 172.31.10.17
interface GigabitEthernet0/0
description *** Shimoga LAN ***
ip address 10.103.170.210 255.255.255.240 secondary
ip address 172.17.192.1 255.255.255.0
ip access-group ACL in
duplex auto
speed auto
media-type rj45
priority-group 1
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/3/0
description *** BHARTI 2MB LL to Mangalore ***
bandwidth 2048
ip address 172.30.2.22 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
service-policy output VideoConf
interface Serial0/3/1
description *** 256K LL to Bangalore ***
bandwidth 256
ip address 172.30.1.22 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
encapsulation ppp
shutdown
interface Serial1/2
no ip address
no ip redirects
encapsulation ppp
shutdown
no cdp enable
interface Serial1/3
no ip address
shutdown
no cdp enable
interface Serial1/4
no ip address
no ip redirects
shutdown
no cdp enable
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
interface BRI3/0
description *** BSNL BRI 08182-222042 ***
no ip address
no ip redirects
encapsulation ppp
ip ospf network point-to-multipoint
shutdown
dialer rotary-group 1
dialer-group 1
isdn point-to-point-setup
no cdp enable
ppp authentication chap
interface BRI3/1
no ip address
encapsulation ppp
shutdown
interface BRI3/2
no ip address
encapsulation hdlc
shutdown
interface BRI3/3
no ip address
encapsulation hdlc
shutdown
interface BRI3/4
no ip address
encapsulation hdlc
shutdown
interface BRI3/5
no ip address
encapsulation hdlc
shutdown
interface BRI3/6
no ip address
encapsulation hdlc
shutdown
interface BRI3/7
no ip address
encapsulation hdlc
shutdown
interface Serial4/0:15
no ip address
no ip redirects
encapsulation ppp
dialer-group 1
isdn switch-type primary-net5
no cdp enable
interface Serial4/1:1
description *** 64K LL to Gonibeedu ***
ip address 172.17.253.113 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
service-policy output FINACLE
interface Serial4/1:2
description *** 64K LL to Badravathi ***
ip address 172.17.253.13 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:3
description *** 64K LL to Malebennur ***
ip address 172.17.253.41 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:4
description *** 64K LL to Balehonnur ***
ip address 172.17.253.29 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:5
description *** 64K LL to Nyamathy ***
bandwidth 64
ip address 172.17.253.45 255.255.255.252
no ip redirects
encapsulation ppp
shutdown
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:7
description *** 64K LL to Shikaripura ***
ip address 172.17.253.49 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:8
description *** 64K LL to Ajjampura ***
ip address 172.17.253.25 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:9
description *** 64K LL to Mudigere ***
ip address 172.17.253.21 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:10
description *** 64K LL to Begar ***
ip address 172.17.253.85 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:11
description *** 64K LL to Sagar ***
ip address 172.17.253.61 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:12
description *** 64K LL to Kadur ***
ip address 172.17.253.117 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:13
description *** 64K LL to Honnali ***
ip address 172.17.253.65 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:14
description *** 64K LL to Chickmagalur ***
ip address 172.17.253.69 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:15
description *** 64K LL to Harihara ***
ip address 172.17.253.53 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:16
description *** 64K LL to Tarikere ***
ip address 172.17.253.17 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:17
description *** 64K LL to Nehru Road ***
ip address 172.17.253.5 255.255.255.252
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:18
description *** 64K LL to RMC Yard ***
ip address 172.17.253.9 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:19
description *** 64K LL to Sasavehalli ***
ip address 172.17.253.97 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:20
description *** 64K LL to Anaji ***
ip address 172.17.253.77 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:21
description *** 64K LL to Holehonnur ***
ip address 172.17.253.89 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:22
description *** 64K LL to Jayapura  ***
ip address 172.17.253.105 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:23
description *** 64K LL to Thirthahalli ***
ip address 172.17.253.57 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:24
description *** 64K LL to Ayanur ***
ip address 172.17.253.101 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:25
description *** 64K LL to Anavatti ***
ip address 172.17.253.93 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:26
description *** 64K LL to Niduvale ***
ip address 172.17.253.81 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:27
description *** 64K LL to Banakal ***
ip address 172.17.253.109 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:28
description *** 64K LL to Chowlahiriyur ***
ip address 172.17.253.73 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:29
description *** 64K LL to Kundur ***
ip address 172.17.253.37 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Serial4/1:30
description *** 64K LL to Hosanagar ***
ip address 172.17.253.33 255.255.255.252
no ip redirects
encapsulation ppp
no cdp enable
crypto map SHMMDL-1
interface Dialer1
ip address 172.17.254.250 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer map ip 172.17.254.205 name Harihara broadcast
dialer map ip 172.17.254.206 name Thirthahalli broadcast
dialer map ip 172.17.254.207 name Sagar broadcast
dialer map ip 172.17.254.208 name Honnali broadcast
dialer map ip 172.17.254.209 name chikmagalur broadcast
dialer map ip 172.17.254.221 name Kadur broadcast
dialer map ip 172.17.254.251 name MLR-Core broadcast
dialer map ip 172.17.254.193 name nehruroad broadcast
dialer map ip 172.17.254.194 name rmcyard broadcast
dialer map ip 172.17.254.195 name badravathi broadcast
dialer map ip 172.17.254.196 name Tarikere broadcast
no cdp enable
router ospf 10
router-id 172.17.192.1
log-adjacency-changes
area 12 stub no-summary
area 12 range 172.17.192.0 255.255.192.0
network 172.17.192.0 0.0.0.255 area 12
network 172.17.253.16 0.0.0.3 area 12
network 172.17.253.0 0.0.0.255 area 12
network 172.17.254.0 0.0.0.255 area 12
network 172.30.1.20 0.0.0.3 area 0
network 172.30.2.20 0.0.0.3 area 0
network 172.30.4.20 0.0.0.3 area 0
ip forward-protocol nd
ip route 172.31.10.17 255.255.255.255 10.103.170.209
no ip http server
no ip http secure-server
ip tacacs source-interface GigabitEthernet0/0
ip access-list extended ACL
permit ip any 172.16.200.0 0.0.7.255
permit ip any 172.16.240.0 0.0.0.255
permit ip any 172.20.0.0 0.0.0.255
permit ip any host 206.201.228.242
permit ip any host 206.201.227.242
permit ip any 172.20.101.0 0.0.0.255
permit ip any 172.20.107.0 0.0.0.255
permit ip any 10.103.170.208 0.0.0.15
permit ip 172.17.192.0 0.0.0.255 172.17.192.0 0.0.0.255
permit ip host 172.17.192.30 any
ip access-list extended BLOCK
deny   ip host 172.16.202.170 any
permit ip any any
ip access-list extended FIN
permit ip 172.16.200.0 0.0.0.255 any
permit ip 172.20.0.0 0.0.0.255 any
permit ip 172.16.207.0 0.0.0.15 any
permit ip host 172.16.202.11 any
permit ip host 172.16.202.12 any
permit ip host 172.16.202.30 any
permit ip host 172.16.202.31 any
permit ip host 172.20.102.132 any
ip access-list extended IPSEC
permit ip host 172.16.240.30 any
permit ip host 172.16.240.28 any
permit ip host 172.20.107.12 any
permit ip host 172.20.103.171 any
permit ip host 172.18.0.150 any
permit ip host 172.18.0.151 any
ip access-list extended MDLIPSEC
permit ip any 172.16.200.0 0.0.0.255
permit ip any host 172.16.240.30
permit ip any host 172.16.240.28
permit ip any host 172.20.107.12
permit ip any host 172.20.103.171
permit ip any host 172.18.0.150
permit ip any host 172.18.0.151
ip access-list extended NAV
permit ip 172.16.202.160 0.0.0.15 any
permit ip host 172.17.0.90 any
permit ip host 172.18.0.61 any
permit ip host 172.19.1.40 any
permit ip host 172.20.101.78 any
permit ip host 172.21.162.164 any
logging source-interface GigabitEthernet0/0
logging 172.16.202.20
dialer-list 1 protocol ip permit
no cdp run
snmp-server community RO
snmp-server host 172.16.202.10
tacacs-server host 172.16.202.250 key 7
tacacs-server host 172.20.101.100 key 7
control-plane
banner motd ^C
        You are logged into KARNATAKA BANK LIMITED  Shimoga Branch
           Only authorised persons are allowed to access the system.
                        All actions will be monitored!!
^C
privilege interface level 10 shutdown
privilege interface level 1 ip accounting output-packets
privilege interface level 10 backup interface
privilege interface level 10 description
privilege interface level 10 no shutdown
privilege interface level 1 no ip accounting output-packets
privilege interface level 10 no backup interface
privilege interface level 10 no description
privilege configure level 1 interface
privilege exec level 10 isdn disconnect interface
privilege exec level 10 isdn call interface
privilege exec level 10 isdn test disconnect interface
privilege exec level 10 isdn test call interface
privilege exec level 1 traceroute
privilege exec level 1 ping
privilege exec level 1 configure terminal
privilege exec level 10 terminal monitor
privilege exec level 1 show isdn history
privilege exec level 1 show isdn active
privilege exec level 1 show isdn status
privilege exec level 1 show controllers
privilege exec level 1 show interfaces
privilege exec level 10 clear counters
line con 0
exec-timeout 5 0
line aux 0
line vty 0 4
exec-timeout 5 0
password 7
scheduler allocate 20000 1000
ntp update-calendar
ntp server 172.16.1.100
end
Krishna
