Not getting multicast data from vlan 10 to vlan 1
Hello All,
We have cisco switch 3650. In that we have two vlans, vlan 1 & vlan 10.
I have assigned IP address to SVI and able to communicate between vlans. Now regarding Multicast data:
We have published data in vlan 10 server and want to populate it into vlan 1 but not getting.
We have configured below parameters:
Switch(config) ip multicast-routing
int vlan 10
ip address 192.168.10.1/24
ip pim dense-mode
int vlan 1
ip add 192.168.20.1/24
ip pim dense-mode
ip pim join-group group-ip(235.2.3.5)
Any suggestion would be very helpful.
balaji.bandi
before we get in to further, is this working in VLAN 10?
BB
Yes
just to make sure, verify that you run anything higher than LAN Base on your switch...
int vlan 1
ip pim dense-mode
--> ip pim join-group group-ip(235.2.3.5)
I assume you mean 'ip igmp join-group' ?
Send a ping to 235.2.3.5, then post the output of 'show ip mroute 235.2.3.5'
Hello
Can vlan 10,1 communicate with each other?
ip routing
If you a simulating a MC host on vlan 1 than the sytax should be;
int x/x
ip igmp join-group x.x.x.x
Lastly post the output
sh ip igmp groups
sh ip igmp interface x/x
Kind Regards
Paul
