Not seeing the gateway ip in attached topology while pinging from Pc2
lohit
HI all,
I have this topology where I am doing static everywhere.
I have a doubt here, I am doing static from 192.168.10.2 (gateway -10.1) to 192.168.30.2. Also, I am doing per packet load balancing on R1 and disabled cef. Now, when i am doing a trace to to 30.2 I am not seeing the gateway for Pc1 i.e 10.1, why so?
Can someone please help me understand this.
When  cef is enabled and LB is per destination than I am seeing 10.1 gateway and by default trace is via R2, the upper path.ss.png.jpg
I dont see anything wrong
You traceroute with LB the traffic go to different path and hence you see different hops.
Can you more elaborate
MHM
post the full running configs of all devices involved, as well as a readable schematic drawing of your topology. It is difficult to see from just the screenshots what you have configured...
