Novice config for 7301<>3750G at home ?
Choc Top
Hello, my apologies if this is in the wrong section, I could not find any newb subforums.
I am looking to do some self study and implement some real world gear, I would like to purchase a used Cisco Router that can load balance 2 x HFC modem links of 100/40Mb and also connect up to 3750G L3 switch I have.
As its just for home use it wouldn't be doing much more than internet stuff + port forwarding.
Googling 'max throughput' turns up some confusing results for various models.
What would you recommend for a used bargain purchase with some future throughput overhead?
Thanks for your time
is your ISP providing the cable modem (which usually means you get an Ethernet handoff), or are you looking for a Cisco router with a Cable Modem HWIC ?
In the first case, any of the 800ISR routers should be sufficient. In the latter, the Cisco 1805 has an integrated cable modem, or you can get a 2800/3800ISR, a 3725/3745, or an 1841 with a Cable Modem HWIC. Whether you can get any of these cheap...depends on your budget.
Check the document below for reference:
Cable Modem High-Speed WAN Interface Cards
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/ic/hardware/installation/guide/cab_hwic.html
HFC modems both supplied.
Although quite old I went with a 7301 w/ 1GB RAM, a bit overkill I know but it had the interfaces I wanted to play with and the right form factor.
*Cable Modem*
-Dynamic IP
*Cisco 7301*
-Gigabit Ethernet 0/0 to Cable Modem
-Gigabit Ethernet 0/2 SFP GBIC to Switch
*Cisco 3750G L3*
-SFP port 52 to Router
-The Eth ports are physically split into 3 sections 1-16, 17-32 & 33-48, I would like 3 separate VLANs for pc/wifi-ap/ipcam to keep it tidy and to learn the process.
First things.
What ip/subnets would you use and on what interfaces to get started?
