ISR4451-K9
Sherdilkhan2015
Hi Guys,
I am having issue with this unit can you please guide me i cannot install IOS from rommon as ISR have no bootable file: Output is given below:
File reception completed.
Boot image size = 424692968 (0x19504ce8) bytes
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated f35e6d42:a361f798:65ad59fb:02177c05:59fada9a
expected beecd4b6:98cc252b:913b643c:acc2ea2b:865dae09
SHA-1 hash doesn't match
application image failed to run
boot: netboot failed
rommon 15 >
Mark Malone
Looks like image might be corrupted corrupted SHA-1 hash doesn't match , is there only one image in flash ?
You could add another one if only 1 then try boot or try boot an image from usb instead , then when its up transfer between usb and flash
rommon 1 > boot usb1:isr4400-universalk9.03.15.01.S.155-2.S1-std.SPA.bin
Thanks for quick reply, I have tried another IOS but the same problem and I have tried to install from USB but Unit is not picking USB it is showing nothing, anyother help please?
so if its not seeing usb then its the wrong format in usb , reformat to FAT then add your image and reinsert then boot
Please post full outout from console if it fails to boot when usb is reformatted
apart form usb you now have 2 images in bootflash yes ? Have you validated the md5 of the images there ok and match what you downloaded ?
