NTP-Server over VRRP
dashping
Hi all,
I need to find a solution for two routers which will act as ntp-servers.
Can I configure them with VRRP to share an virtual IP or is there a better way?
Thanks in advance
gaston.benitez
I made a small lab to test this and I think this may help you about your questions
# Lab example
EIGRP used between routers to have access to their loopbacks
/// R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.1.12.1 255.255.255.0
vrrp 1 ip 10.1.12.3
vrrp 1 priority 120
ntp master 1
/// R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 10.1.12.2 255.255.255.0
vrrp 1 ip 10.1.12.3
ntp server 1.1.1.1
/// R3
ip address 10.1.12.100 255.255.255.0
ntp server 10.1.12.3
/// Verifications from R3
From R3 we can ping VIP address and we are able to set the VIP as ntp server
R3#ping 10.1.12.3
Sending 5, 100-byte ICMP Echos to 10.1.12.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/20/24 ms
R3#
R3#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R3(config)#ntp server 10.1.12.3
R3(config)#end
R3#
R3#show ntp status
Clock is synchronized, stratum 2, reference is 10.1.12.3
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**16
ntp uptime is 1100 (1/100 of seconds), resolution is 4000
reference time is C0294827.CFE78FBE (00:21:59.812 UTC Fri Mar 1 2002)
clock offset is -23.9935 msec, root delay is 23.99 msec
root dispersion is 3977.54 msec, peer dispersion is 3937.52 msec
loopfilter state is 'CTRL' (Normal Controlled Loop), drift is 0.000000000 s/s
system poll interval is 64, last update was 1 sec ago.
R3#
/// Verifications from R1 and R2 (VRRP)
R1#show vrrp
FastEthernet0/0 - Group 1
State is Master
Virtual IP address is 10.1.12.3
Virtual MAC address is 0000.5e00.0101
Advertisement interval is 1.000 sec
Preemption enabled
Priority is 120
Master Router is 10.1.12.1 (local), priority is 120
Master Advertisement interval is 1.000 sec
Master Down interval is 3.531 sec
R1#
R2#show vrrp
State is Backup
Preemption enabled
Priority is 100
Master Router is 10.1.12.1, priority is 120
Master Down interval is 3.609 sec (expires in 3.509 sec)
R2#
/// Verifications from R1 and R2 (NTP)
R1#show ntp status
Clock is synchronized, stratum 1, reference is .LOCL.
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18
reference time is C029485C.384E8DA8 (00:22:52.219 UTC Fri Mar 1 2002)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.02 msec, peer dispersion is 0.02 msec
R1#
R2#show ntp status
Clock is synchronized, stratum 2, reference is 1.1.1.1
ntp uptime is 135900 (1/100 of seconds), resolution is 4000
reference time is C0294775.97D95CFA (00:19:01.593 UTC Fri Mar 1 2002)
clock offset is -5038.2055 msec, root delay is 7.86 msec
root dispersion is 8556.47 msec, peer dispersion is 4.86 msec
loopfilter state is 'SPIK' (Spike), drift is -0.000000000 s/s
system poll interval is 64, last update was 303 sec ago.
R2#
####### Redundancy forcing a switching in vrrp making R2 primary
R1#conf t
R1(config)#interface FastEthernet0/0
R1(config-if)# vrrp 1 priority 80
R1(config-if)#end
R1#
Mar 1 00:25:22.415: %VRRP-6-STATECHANGE: Fa0/0 Grp 1 state Master -> Backup
R1#
R1#show vrrp
State is Backup
Preemption enabled
Priority is 80
Master Router is 10.1.12.2, priority is 100
Master Down interval is 3.687 sec (expires in 3.151 sec)
R1#
R3 is still synchronized
R3#show ntp status
Clock is unsynchronized, stratum 3, reference is 10.1.12.3
ntp uptime is 83300 (1/100 of seconds), resolution is 4000
reference time is C0294B23.C9A069CD (00:34:43.787 UTC Fri Mar 1 2002)
clock offset is -986.6018 msec, root delay is 17.08 msec
root dispersion is 8944.68 msec, peer dispersion is 0.99 msec
loopfilter state is 'SPIK' (Spike), drift is 0.000000000 s/s
system poll interval is 64, last update was 59 sec ago.
R3#
I hope this information be usefull for you
BR
Gaston
gaston.benitez
# Lab example
/// R1
interface Loopback0
vrrp 1 ip 10.1.12.3
vrrp 1 priority 120
ntp master 1
/// R2
interface Loopback0
vrrp 1 ip 10.1.12.3
ntp server 1.1.1.1
/// R3
R3#ping 10.1.12.3
R3#
R3#conf t
R3(config)#end
R3#
R3#show ntp status
R3#
R1#show vrrp
State is Master
Preemption enabled
Priority is 120
R1#
R2#show vrrp
State is Backup
Preemption enabled
Priority is 100
R2#
R1#show ntp status
R1#
R2#show ntp status
R2#
R1#conf t
R1(config-if)#end
R1#
R1#
R1#show vrrp
State is Backup
Preemption enabled
Priority is 80
R1#
R3#show ntp status
R3#
BR
Gaston
Hi Gaston,
Thanks for your lab example. It cleared some questions, but a single one still remains.
I wanted to check if it is possible to have R2 also act as a ntp master which would serve (if needed) R3.
Still, thanks for the detailed response, I'm going to mark it as the solution.
Kind Regards
dashping
