NTP server
amansoi_5
Can somebody guide me how NTP works & what are the commands to configure on Cisco router ..?
mheusinger
Level 10
Level 10
a complete description on how to configure NTP on a Cisco router can be found in "Configuring NTP" at
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008030c799.html#wp1001170
The probably simplest method is to specify a NTP server with "ntp server ". NTP used UDP port 123 (source and destination), and you should enable connectivity for this type of communication.
Another good source of information would be http://www.eecis.udel.edu/~mills/ntp.html
and a list of public NTP servers on the internet can be found at http://ntp.isc.org/bin/view/Servers/WebHome
Hope this helps! Please rate all posts.
Regards, Martin
mheusinger
Level 10
Level 10
Regards, Martin
thanks ...
