HA IPSec reload
todd.martin-02
I have an HA IPSec router pair that has HSRP between them. In a normal senario when a link fails it causes the router to reload.
I would like to delay the reload up to 5 seconds after a link failure to prevent erronious reloads.
does anyone know if there is a configuration to delay the reload? this is the section that I believe the delay would be configured.
ipc zone default
association 1
no shutdown
protocol sctp
local-port 5555
local-ip 10.10.10.1
retransmit-timeout 500 15000
path-retransmit 10
remote-port 5555
remote-ip 10.10.10.2
m.matteson
Level 2
Level 2
try
standby [group-number] priority
priority [preempt [delay [minimum |
sync] delay]]
Thanks but no cigar.
It did not delay te reload upon link failure.
I thought that the reload was a function of SCTP. and the ha redundandcy scheme inter-device.
any other ideas?
afaik there is no "reload delay timer". So the only option I can think of would be to experiment with interface keepalive timers to overcome short link flaps. This will of course depend on the type of interface and L2 protocol in place.
Hope this helps! Please rate all posts.
Regards, Martin
