NTP strange error
kthned
Level 3
Level 3
Does any one has an idea about the reason of following NTP error. I am unable to configure further ntp peers on the router. Could not able to understand the reason of 100 peers. I am adding only 2nd peer on the router but getting this error. There is no problem adding peers in other 6500s .
6500(config)#ntp peer 192.x.x.x
%NTP: Did not configure master clock.  Too many peers(101). Allowed only 100
%NTP: Couldn't configure peer
Here is the actual config on the router
        ntp source Loopback0
ntp access-group peer 15
ntp access-group serve-only 16
ntp update-calendar
ntp server 192.a.a.a
ntp server 192.b.b.b
ntp peer 123.c.c.c
ntp server 192.c.c.d prefer
I want to add two more peers, in a mesh configs.
Hope to get your kind help !
Umair
cadet alain
look at this: http://www.cisco.com/en/US/docs/ios/12_3t/fun/command/reference/cfrgt_05.html#wp1117857
Regards.
Alain
I manage to increase the max-association from 100 to 110 and now 6500 accepts the "ntp peer ..." command. The million dollar question is 100 is too high number for associations. I am sure there are only 6 to 7 peer / server configured and just few client. Yes there are lot many broadcast clients but i dont think they are counted towards the association as it is only one way communication.
Umair
