Getting error on enabling ip routing in L3 switch
Hi all,
I am really stuck in enabling ip routing though a simple task.
I have configured 10 vlans in stacked 3750 switches have ipbase image.
I want to enable ip routing for inter vlan communication but it is giving this error:
%COMMON_FIB-4-ISSUENCODEWRONGLEN: Message IPv6 global features, rev B for slots 2 (0x4) is wrong length (10, should be 7).
Any help will be really appreciated.
Sandeep Choudhary
HI Abdul,
CSCtb36844 - Catalyst 3750 stack output %COMMON_FIB when enable ip routing.
Known Affected Versions: (49)
12.2(55)SE,12.2(54)SE,12.2(53)SE2,12.2(53)SE1
12.2(53)SE,12.2(53)EY,12.2(53)EX,12.2(52)EX1
Fixed in: (1)
12.2(52)SE
Symptom:
Catalyst 3750 stack output %COMMON_FIB-4-ISSUENCODEWRONGLEN
Conditions:
- Catalyst 3750 stack.
- c3750-ipservicesk9-mz.122-50.SE3
Workaround:
There is no workaround.
Further Problem Description:
This is cosmetic problem
Please rate if it helps.
5 Replies 5
Dear Friend,
I have this for you
Error Message
%COMMON_FIB-4-ISSUENCODEWRONGLEN : Message %s for slots %s is wrong length (%d, should be %d)
Explanation    The encoded message length doesn't match the expected length. Message will not be sent.
Recommended Action    Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at
http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at
http://tools.cisco.com/ServiceRequestTool/create/http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
Please refer to the link
http://www.cisco.com/en/US/docs/ios/system/messages/guide/sm_cn03.html#wp616470
Please rate the helpful posts.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Which version are you running? Perhaps there is a more stable IOS-version available for your switch.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Sandeep Choudhary
HI Abdul,
Fixed in: (1)
12.2(52)SE
Symptom:
Conditions:
Workaround:
Thanks for your help everybody.
I dont know what was the issue but i think most probably it was due to stacking as when i removed stack and reconfigured the switches seperately everything is working fine!!!
@sandeep what does cosmetic problem mean???
does that mean it does not effect any functionality.
Hi Abdul,
Cosmetic Bug means:
a software error condition that does not impact a system in any functional way; types of errors can include spelling mistakes, transient error message
here is the link for full explanation:
http://notanothernetworkblog.net/2012/05/03/cosmetic-bug-is-is-network-entity-title/
