NTP Sync on Nexus 7000-5000
Hello, guys.
How do I know if ntp is synchronized or not?
The output is the following:
show ntp peer-status
Total peers : 1
* - selected for sync, + - peer mode(active),
- - peer mode(passive), = - polled in client mode
remote     local     st poll reach delay     vrf
*X.X.X.X  Y.Y.Y.Y  2  64   377  0.00272 management
show ntp statistics peer ip X.X.X.X
remote host: X.X.X.X
local interface: Y.Y.Y.Y
time last received: 36s
time until next send: 24s
reachability change: 206616s
packets sent: 34825
packets received: 34561
bad authentication: 0
bogus origin: 0
duplicate: 0
bad dispersion: 7
bad reference time: 0
candidate order: 6
johnd2310
Level 8
Level 8
You should determine sync status sing the following commands:  show ntp status and show ntp association.
John
**Please rate posts you find helpful**
Hi John,
that commands doesnt show relevant information, remember that Nexus platform use the NX-OS, the output isnt the same to ios.
Anybody?
