Nullo
er.vansh17091
Hello Folks,
While tracing the routes I found null0 next hop.
How can I trace the routes further?
Giuseppe Larosa
Hello @er.vansh17091 ,
You cannot null0 = waste bin all packets sent to null0 are silently dropped so it is a final destination.
Usually this means the destination of the packet matches a static route to null0.
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
Thanks for the response, is there anyway to check the next hop or route?
you can use
show ip route <destination-address>
to verify that the destination is part of a prefix sent to null0
Hope to help
Giuseppe
I tried but that is coming under Null 0 interface.
