NX-OS Upgrade
zekebashi
Level 4
Level 4
Current NXOS release version on our NX7K is 7.3(0)D1(1). The next release version is 7.3(0)DX(1) and the next one up is 7.3(1)D1(1). My question is can I upgrade directly from 7.3(0)D1(1) to 7.3(1)D1(1) or do I need to do it in a sequential order?
Thanks in advance.
Best, ~zK
cofee
Level 5
Level 5
This command can be used to check if the image will be disruptive or non disruptive. Replace the image name with the one you will be upgrading to, but you need to have new image loaded in the flash before you can use this feature.
N7K1# show install all impact kickstart bootflash:n7000-s1-kickstart.5.0.3.bin system bootflash:n7000-s1-dk9.5.0.3.bin
Thanks.
I was hoping not to have to download all 4 images [(7.3(0)DX(1) and the next one up is 7.3(1)D1(1)] and try the above command.
I might have to do it that way if no one else posts an answer.
Thanks again.
Best, ~zK
