NAT Overload from Multiple Inside VRFs
Daryl Clark
I have one outside, public interface with a single IP. That interface is in VRF INTERNET. I have two internal VRFs for GUEST and CONTRACTOR internet access that I need segmented. This is all separate from the global routing table for corporate devices. My NAT overload is not working as I am not seeing any NAT Translations and users have no internet. If i put the internet access VLANs in the same VRF as the outside interface, it works. Any ideas?
See config below.
vrf definition IWAN-INTERNET
address-family ipv4
exit-address-family
vrf definition GUEST
address-family ipv4
exit-address-family
vrf definition BYOD
address-family ipv4
exit-address-family
ip dhcp pool GUEST
vrf GUEST
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 208.67.222.222 208.67.220.220
ip dhcp pool BYOD
vrf BYOD
ip nat inside source list 100 interface GigabitEthernet0/0/2 vrf GUEST overload
ip nat inside source list 100 interface GigabitEthernet0/0/2 vrf BYOD overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
int gig 0/0/1.300
vrf forwarding BYOD
encapsulation dot1q 300
ip nat inside
ip virtual-reassembly
int gig 0/0/1.301
vrf forwarding GUEST
encapsulation dot1q 301
ip nat inside
vrf forwarding IWAN-INTERNET
ip address <public ip>
ip nat outside
ip access-group IWAN-INTERNET-IN in
negotiation auto
ntp disable
5 Replies 5
Collin Clark
It sounds like you are not sharing any routes between the VRF's. The CONTRACTOR and GUEST need to know their default gateway to the internet. http://packetlife.net/blog/2010/mar/29/inter-vrf-routing-vrf-lite/
Thanks for the quick response, follwoing that guide, I now have:
vrf definition BYOD
rd 65000:300
route-target export 65000:300
route-target import 65000:2
address-family ipv4
exit-address-family
rd 65000:301
route-target export 65000:301
address-family ipv4
exit-address-family
rd 65000:2
route-target export 65000:2
route-target import 65000:300
route-target import 65000:301
address-family ipv4
exit-address-family
However my routing tables dont show the shared routes:
RICRAN2115-4331#sh ip route vrf IWAN-INTERNET
Routing Table: IWAN-INTERNET
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 98.174.xx.xxx to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 98.174.81.193
98.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 98.174.xx.xxx/27 is directly connected, GigabitEthernet0/0/2
L 98.174.xx.xxx/32 is directly connected, GigabitEthernet0/0/2
Hello.
Just FYI - inter-VRF NAT is not supported with legacy (ip nat inside/outside) configuration. And for inter-VRF communication/NAT you may need to use VASI.
PS: even though it may work and was a part of DIA design guide (Mar2015), but TAC would most probably decline support.
You must start BGP on the router
Reza Sharifi
Can you add below statement for vrf GUEST and test?
ip route vrf GUEST 0.0.0.0 0.0.0.0 GigabitEthernet0/0/2 <provider side ip>
