o2 dsl - 1483 bridge
Jinesh Patel
I am having trouble connecting my 887 to my o2 broadband service.  Here is my configuration -
sh run
Building configuration...
Current configuration : 1684 bytes
! Last configuration change at 21:36:59 UTC Tue Jan 17 2012
! NVRAM config last updated at 21:36:55 UTC Tue Jan 17 2012
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
ip name-server xxx.xxx.xxx.xxx
no ipv6 cef
license udi pid CISCO887-SEC-K9 sn FCZ1549C1KE
bridge irb
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
mac-address yyyy.yyyy.yyyy (of my old o2 router)
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address xx.xxx.xxx.x 255.255.248.0
ip pim sparse-dense-mode
ip nat outside
ip virtual-reassembly
atm route-bridged ip
pvc 0/101
  oam-pvc manage
  encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.10.5.1 255.255.255.128
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface ATM0.1 overload
ip route 0.0.0.0 0.0.0.0 ATM0.1
access-list 1 permit 10.10.5.0 0.0.0.128
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
password xxxxxxxxx
login
no modem enable
line aux 0
line vty 0 4
password xxxxxxxxx
login
scheduler max-task-time 5000
end
Interface atm0, atm0.1, bvi and vlan are all up/up
O2 have verified the vpi, vci, SM settings using LLC
I'm getting a solid cd light but no internet/ability to ping anything even from the router
Can anyone help?
J
That was an overlook by my side too. I should have noticed and told you that with bridged RFC1483 you can't have:
Instead, one has to use to the correct default gateway address, as you confirmed.
6 Replies 6
paolo bevilacqua
Try moving the cloned mac under atm0.1
The take show interface atm0.1, show atm pvc 0/101.
Thanks for replying Paolo......
I can't move the mac into atm0.1 (unrecognised command)
I can't switch atm and atm0.1 configs around either for the same reason
But here are the sh command outputs that you needed -
Router#sh atm pvc 0/101
Description: N/A
ATM0.1: VCD: 1, VPI: 0, VCI: 101
UBR, PeakRate: 1000 (2359 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0x1840, VCmode: 0x0, Encapsize: 12
OAM frequency: 10 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM END CC Activate retry count: 3, OAM END CC Deactivate retry count: 3
OAM END CC retry frequency: 30 second(s),
OAM SEGMENT CC Activate retry count: 3, OAM SEGMENT CC Deactivate retry count: 3
OAM SEGMENT CC retry frequency: 30 second(s),
OAM Loopback status: OAM Received
OAM VC Status: Verified
OAM Loop detection: Disabled
ILMI VC status: Not Managed
VC is managed by OAM.
InARP DISABLED
InPkts: 2114, OutPkts: 3980, InBytes: 197439, OutBytes: 294676
InPRoc: 2114, OutPRoc: 3961, Broadcasts: 19
InFast: 0, OutFast: 0, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 48
F5 InEndloop: 48, F5 InSegloop: 0,
F5 InEndcc: 0, F5 InSegcc: 0, F5 InAIS: 0, F5 InRDI: 0
OAM cells sent: 48
F5 OutEndloop: 48, F5 OutSegloop: 0,
F5 OutEndcc: 0, F5 OutSegcc: 0, F5 OutAIS: 0, F5 OutRDI: 0
OAM cell drops: 0
Status: UP
Router#sh int atm0.1
ATM0.1 is up, line protocol is up
  Hardware is MPC ATMSAR (with Alcatel ADSL Module), address is 0024.17b0.a70c (
bia 2894.0f06.0ada)
  Internet address is x.x.x.x/21
  MTU 4470 bytes, BW 1004 Kbit/sec, DLY 360 usec,
     reliability 255/255, txload 2/255, rxload 1/255
  Encapsulation ATM
  Keepalive not supported
     130 packets input, 12153 bytes
     655 packets output, 48494 bytes
     12 OAM cells input, 12 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
J
Can you ask O2 if they have a MAC lock and if so, clear it.
Hi Paolo,
O2 do not have a mac lock but thnakfully, the problem is now resolved.  The issue seemed to be as simple as the DG.  Once i pushed all traffic out of the DG associated with the subnet that i was on rather than one that was given to me, everything appeared to work correctly.
Thanks so much for your help
Regardless, your help was invaluable in getting to the root of the problem.  Thanks so much.
Hopefully you'll be able to help with some further discussions
J
