object-group ACL issues
Hi all,
I am currently building an object-group based ACL for use on my Internet-facing router (A Cisco 897VA-K9 running IOS 15.3-3.M5)
I have defined my object-groups and created an ACL entry for them but it appears traffic which matches the objects in the object-group is still being blocked. I feel like i'm doing something wrong!
Here's my config (cut down to only show relevant sections):
object-group service MerakiPorts
 udp eq 7351
 udp eq 1812
 tcp eq 7734
 tcp eq 7752
object-group network MerakiServers
 host 54.193.207.248
 host 64.62.142.12
 host 64.62.142.2
 185.17.255.128 255.255.255.128
 185.92.120.0 255.255.255.128
 199.231.78.0 255.255.255.0
 50.115.86.96 255.255.255.224
object-group service PSNPorts
 udp eq 3478
 udp eq 3479
 udp eq 3658
 udp eq 10070
interface Dialer0
ip access-group outside-in in
ip access-list extended outside-in
 remark ***INBOUND from Internet***
 remark ---General web---
 permit tcp any any established
 permit udp host 208.67.222.222 eq domain any
 permit udp host 8.8.8.8 eq domain any
 permit udp any eq ntp any
 remark ---PING---
 permit icmp any any echo-reply
 permit icmp any any traceroute
 remark ---PS4---
  remark >>>General PSN<<<
 permit object-group PSNPorts any any
 remark ---Synology---
 remark >>>BitTorrent<<<
 permit tcp any any eq 51413
 permit udp any any eq 51413
 remark >>>PlexServer<<<
 permit tcp any any eq 32400
 remark >>>WakeOnLAN<<<
 permit udp any any eq echo
 remark ---Meraki management---
 permit object-group MerakiPorts object-group MerakiServers any log-input
 deny   ip any any log-input
...And i'm seeing the following logs:
Oct  8 17:07:15.699: %SEC-6-IPACCESSLOGP: list outside-in denied udp 185.17.255.157(7351) (Dialer0 ) -> <my_ip>(46468), 1 packet
Oct  8 17:07:54.752: %SEC-6-IPACCESSLOGP: list outside-in denied udp 64.62.142.12(7351) (Dialer0 ) -> <my_ip>(45313), 7 packets
Oct  8 17:09:54.754: %SEC-6-IPACCESSLOGP: list outside-in denied udp 185.17.255.157(7351) (Dialer0 ) -> <my_ip>(46750), 7 packets
Oct  8 17:09:54.754: %SEC-6-IPACCESSLOGP: list outside-in denied udp 50.115.86.110(7351) (Dialer0 ) -> <my_ip>(44254), 50 packets
Oct  8 17:09:54.754: %SEC-6-IPACCESSLOGP: list outside-in denied udp 54.193.207.248(7351) (Dialer0 ) -> <my_ip>(42183), 8 packets
Any ideas would be greatly appreciated.
Cheers
Hi, can you share the
sh object-groups and sh access-list outside-in
just to see what it looks like
thanks
Richard
To my knowledge, putting the service object group into the protocol field of the ACE only filters on the destination. But the denied traffic in your log is return-traffic for sessions that are originated in your network.
The easiest would be to handle return traffic by activating a statefull inspection like the following:
ip inspect name FW tcp router-traffic
ip inspect name FW udp router-traffic
ip inspect name FW icmp router-traffic
ip inspect name FW ftp
interface dialer 0
 ip inspect FW out
This is an old message thread and it might have been solved already in which case I apologize for the late entry.
It appears to me that the permit line is scrambled.  Shouldn't it be
permit object-group MerakiServers object-group MerakiPorts any log-input
rather than
In other words, IP addresses before ports rather than after?
No, the object-group with the services is located correctly where normally the protocol is specified. That is correct.
